e-pie
- 129
- 18
Ibix said:And there are twenty independent components in general:
Bianchi Identity?
4C4=1 21-1=20 ?
To put this in a slightly different way: The spherical symmetry of the Schwarzschild spacetime means additional constraints on the components of the Riemann tensor. For the general N-dimensional case (without symmetries in the spacetime) is ##N^2(N^2-1)/12##, which follows from first checking the number of components allowed by the symmetries of the tensor and then removing some due to the Bianchi identity.Ibix said:Most of them are zero in the Schwarzschild metric. It's only the remaining ones we care about. And there are twenty independent components in general: http://mathworld.wolfram.com/RiemannTensor.html
Yeah I got the point and answer here at https://physics.stackexchange.com/q...he-riemann-tensor-of-the-schwarzschild-metricIbix said:MTW says on page 821 that there are other non-zero components obtainable by symmetries of the Riemann. I'm not sure about the all-lower-index Riemann that they are using, but there are twelve non-zero components in the (1,3) form you seem to be using (although on a re-read I'm not certain you have the lower indices in the order I expected - I think what you've called ##R^t{}_{rtr}## is usually ##R^t{}_{rrt}##, although it's possible I've got lost in the different notations used by different sources).
That means, ... Detail not shown after using Bianchi and swappingOrodruin said:To put this in a slightly different way: The spherical symmetry of the Schwarzschild spacetime means additional constraints on the components of the Riemann tensor. For the general N-dimensional case (without symmetries in the spacetime) is N2(N2−1)/12N2(N2−1)/12N^2(N^2-1)/12, which follows from first checking the number of components allowed by the symmetries of the tensor and then removing some due to the Bianchi identity.
Predictions are not coordinate dependent and the KS coordinates are just a different set of coordinates on the Schwarzschild spacetime. Perhaps a result of how it is often being taught with emphasis on coordinates and coordinate transformations, students often make this mental mistake. Bottom line: The spacetime does not change just because you change coordinates.Bishal Banjara said:Hello lbix,
Just take it as my innocence and reply me, does the Kruskal-Szekeres coordinate transformation passes all the test of Schwarzschild Solution like light bent, mercury precision,...?
Hello Orodruin,Orodruin said:Predictions are not coordinate dependent and the KS coordinates are just a different set of coordinates on the Schwarzschild spacetime. Perhaps a result of how it is often being taught with emphasis on coordinates and coordinate transformations, students often make this mental mistake. Bottom line: The spacetime does not change just because you change coordinates.
No, this is wrong. Vectors and tensors do not change when you change coordinates - their components change but that is only in response to a change in the basis used to describe them. In the case of the Schwarzschild spacetime, the Schwarzschild coordinates are singular at ##r = 2MG## and therefore not a good basis to use, meaning that you cannot use it properly at that coordinate.Bishal Banjara said:I argue that if we change the coordinate there will be the change in Riemann curvature tensor (like at the case of the event horizon), doesn't this effect on the line element itself.
Remember that these equations are a description of "real" things. It turns out this description is a little complicated, but very accurately describes what we observe in intermediate range physics: colliding stars, black holes...Bishal Banjara said:Hello Orodruin,
I argue that if we change the coordinate there will be the change in Riemann curvature tensor (like at the case of the event horizon), doesn't this effect on the line element itself. Do we have some sortie reference in that regard? Thank you for your response.
I am sorry, but it is completely unclear what "tests" you are referring to. What you have quoted here are the components of the metric in Schwarzschild coordinates. In a different coordinate system, those components will be different, but the metric itself is still the same metric.Bishal Banjara said:If so, then let us assume that the $$g_{tt}$$ and $$g_{rr}$$ being like in the form $$(1+2GM/r)$$ and $$(1+2GM/r)^{-1}$$ respectively. Do such tests remain independent again where we have no singularity at r=2GM?
I mean the precision of Mercury, light bent,..and so on. Does this form of metrics still don't effect on these tests?Orodruin said:I am sorry, but it is completely unclear what "tests" you are referring to. What you have quoted here are the components of the metric in Schwarzschild coordinates. In a different coordinate system, those components will be different, but the metric itself is still the same metric.
The form of the metric does not matter, because the theory is about the manifold (space-time). The tests are meant to check that gravity is the change in the underlying mesh of space-time. The form of tensors, like the metric, you need for doing calculations. The same way we represent a vector as an arrow and we do not need to know about any coordinate system nor what its components are. But if you are to solve a problem requesting you to give, say, a speed, then you need to go into numbers. Then you need to know the components.Bishal Banjara said:I mean the precision of Mercury, light bent,..and so on. Does this form of metrics still don't effect on these tests?
But if you are to solve a problem requesting you to give, say, a speed, then you need to go into numbers. Then you need to know the components. Don't these tests are the results of respective components and get affected due to such change in metric values?kent davidge said:The form of the metric does not matter, because the theory is about the manifold (space-time). The tests are meant to check that gravity affects space-time, affecting the "underlying mesh". The form of tensors, like the metric, you need for doing calculations. The same way we represent a vector as an arrow and we do not need to know about any coordinate system nor what its components are. But if you are to solve a problem requesting you to give, say, a speed, then you need to go into numbers. Then you need to know the components.
So for actually computing the tests of General Relativity, you need to know the components, which is done through a coordinate system. But they do not affect the tests in the sense you seem to think.
No, think of it this way: you are at the entrance of a tunnel, the result is at the exit and the components are the tunnel. They are a path linking you to the result, but the result is out there whether or not you have the components. Therefore they cannot affect the results.Bishal Banjara said:Don't these tests are the results of respective components?
This means that it is alike the coordinate transformation as like the KS. Am I right?kent davidge said:No, think of it this way: you are at the entrance of a tunnel, the result is at the exit and the components are the tunnel. They are a path linking you to the result, but the result is out there whether or not you have the components. Therefore they cannot affect the results.
Stated a little differently: The numbers you use in all your intermediate computations will, in general, depend on your choice of coordinates. However, regardless of the coordinate system, the numbers will in the end conspire to produce the same result.kent davidge said:No, think of it this way: you are at the entrance of a tunnel, the result is at the exit and the components are the tunnel. They are a path linking you to the result, but the result is out there whether or not you have the components. Therefore they cannot affect the results.
This means I could reach the top hill from all sides around (conceptually linking the least action principle).Orodruin said:Stated a little differently: The numbers you use in all your intermediate computations will, in general, depend on your choice of coordinates. However, regardless of the coordinate system, the numbers will in the end conspire to produce the same result.
Bishal Banjara said:let us assume that the
g_{tt}
and
g_{rr}
(1+2GM/r)
and
(1+2GM/r)^{-1}
respectively.
Orodruin said:What you have quoted here are the components of the metric in Schwarzschild coordinates.
It was just a different value of metric I wrote by assuming as a variable value whether it is still true to itself again. And there is nothing more.PeterDonis said:Are you intending these to be the standard Schwarzschild coordinate forms? If so, you've written them down wrong, there should be minus signs, not plus signs.
If you intend these to be as you have written them, with the plus signs, then they must be the metric coefficients in some other coordinate chart, and you're going to need to specify what chart and how you are obtaining these coefficients. You can't just wave your hands and write down anything you like.
Bishal Banjara said:It was just a different value of metric I wrote by assuming as a variable value whether it is still true to itself again.
If you had seen my previous comments, you would understand what I meant. I am simply focusing that the form of the variable metric values for Schwarzschild line element (like as I mentioned above) will keep revision for the Classical test like precession of mercury, light bent,...or not.PeterDonis said:I have no idea what you mean by this. You can't just write down any "variable value" you like and expect it to describe the same metric (spacetime geometry).
Bishal Banjara said:If you had seen my previous comments, you would understand what I meant.
Bishal Banjara said:I am simply focusing that the form of the variable metric values for Schwarzschild line element (like as I mentioned above)
I was in search of this kind of critical answer. Thank you! Ok, let's assume I have such kind of metric values as I wrote (I am intending not to modify Schwarzschild metric) by derivation itself. Then, it will not be Schwarzschild, right? And I think this change will bring the change in such predictive values for such Tests, am I right?PeterDonis said:I have read all of your previous comments. I don't think the problem is my not understanding what you meant; I think the problem is that you don't understand what you are doing. See below.
You are still missing my point: how do you know that the metric values you wrote down in post #41 are for the Schwarzschild line element? You can't just assume that. You have to prove it.
I don't think the metric values you wrote down in post #41 have anything at all to do with the Schwarzschild line element; they don't describe that spacetime geometry. Which means those values are completely irrelevant to the question it seems like you are trying to ask.
The question it seems like you are trying to ask is: if we change coordinate charts but keep the spacetime geometry the same, will all of the invariants, such as curvature invariants at ##r = 2M##, stay the same? The answer to that question is yes. But what you wrote in post #41 is irrelevant to that question, because the metric coefficients you wrote in post #41 do not represent a change of coordinate charts while keeping the spacetime geometry (Schwarzschild) the same.
Your metric is senseless in the framework of GR. First of all, it does not even have the correct signature. Second, you cannot just write down a metric and hope that it describes anything useful. Third, even if it did, it would have a Einstein tensor (and therefore energy-momentum tensor) that would be different from the one of the Schwarzschild spacetime and therefore not describe the spacetime outside a point mass. It would be like writing down a random gravitational potential in Newtonian gravity in the vain hope that it would describe something.Bishal Banjara said:I was in search of this kind of critical answer. Thank you! Ok, let's assume I have such kind of metric values as I wrote (I am intending not to modify Schwarzschild metric) by derivation itself. Then, it will not be Schwarzschild, right? And I think this change will bring the change in such predictive values for such Tests, am I right?
Bishal Banjara said:Ok, let's assume I have such kind of metric values as I wrote (I am intending not to modify Schwarzschild metric) by derivation itself. Then, it will not be Schwarzschild, right?
PeterDonis said:So you are intending not to modify the Schwarzschild metric, but you are asking if the metric will not be Schwarzschild? This makes no sense.
The values of observable quantities related to the spacetime geometry (which I think is what you mean by "Tests") will obviously be different for different spacetime geometries. As far as I can tell, that answers the actual question you are asking. But that answer has nothing whatever to do with what coordinates you choose.
Sorry that I made mistake with signature. I was intended to write $$-(1+2GM/R)$$ for $$g_{tt}$$ metric. However, if you do have a spacetime that has the correct metric signature, is a solution to the EFEs for some reasonable energy-momentum tensor, then it will generally be different from the Schwarzschild spacetime. I think this point will be applied then.Orodruin said:Your metric is senseless in the framework of GR. First of all, it does not even have the correct signature. Second, you cannot just write down a metric and hope that it describes anything useful. Third, even if it did, it would have a Einstein tensor (and therefore energy-momentum tensor) that would be different from the one of the Schwarzschild spacetime and therefore not describe the spacetime outside a point mass. It would be like writing down a random gravitational potential in Newtonian gravity in the vain hope that it would describe something.
Furthermore, I have read all your posts in the thread and I agree with @PeterDonis , it is very difficult to understand what you mean because it seems you do not control the basic terminology.
