How to calculate the Riemann curvature at r=2GM?
  • Thread starter Thread starter Bishal Banjara
    Curvature Riemann
Bishal Banjara
As the coordinate singularity at r=2GM doesn't mean a physical singularity as Riemann curvature tensor is smooth although [g][/rr] metric behaves oddly in the case of Schwarzschild solution. Do somebody tell me an authentic reference how is this value is calculated? I have references writing different values directly without proper calculation. I found a document dealing with the problem (@gary Oas ) but it will result finally [R][/11]=0. See page 5 and insert all values thus derived in https://web.stanford.edu/~oas/SI/SRGR/notes/SchwarzschildSolution.pdf
##R_{11}## is a component of the Ricci tensor, not the Riemann tensor. Which one are you trying to compute? If the coordinates are not good there, then you need to choose different coordinates.
Likes Bishal Banjara
Hello Martinbn, thank you for your consideration. Yes, in a definite sense it is Ricci Tensor. I particularly want to know how the values inserted for Riemann curvatures components at pp. 821 of Gravitation book (1st Edn) taking the reference to equations (14.50 and 14.51) are calculated. And I see the problem with Ricci Tensors Calculation in a way that the full insertion of all values in all such tensors individually finally result in zero, like R_00=R_11...=0. I think such individually zero is not true, am I wrong?
This one?
Hello e-pie, that's one.
Google Scholar has some papers on this. You will have to browse through them because I am not an expert in GR. I certainly can understand some of the math but not enough.
I will link them one by one.
But what book? Author?
Note that "Gravitation" is usually known as Misner, Thorne and Wheeler, or just MTW.
Page 821 notes that you substitute ##e^{2\Phi}=e^{-2\Lambda}=1-2M/r## into 14.51 (p 360/361). You'll need to calculate derivatives of ##\Phi## and ##\Lambda##, although fortunately they have no time dependency. Then you can read off the Riemann components from 14.50. Note that this gives the Riemann in a mixed form, ##R^{\mu\nu}{}_{\alpha\beta}##, whereas page 821 uses the completely lowered form, ##R_{\mu\nu\alpha\beta}##, so you'll have to lower two indices to get the values given there. Note also that the book says that there are more non-zero components of the Riemann than those listed - you can use its symmetries to determine which ones.
Each component of the Ricci tensor should be zero in this case. How did you calculate it?
I'm guessing you missed one or other of the index raising/lowerings, or the components of the Riemann that MTW doesn't state explicitly, if you are having problems.
Attributed to Louis Leestemaker of Amsterdam City College
See pages 18 to 20 of pdf file.
From http://www.uva.nl
I think the pdf is free-for-all. So I am uploading it.
Edit. I see @lbix has joined who I think is an expert on GR. You can refer to him.
<< Mentor Note -- PDF deleted; please follow the link to the text. Thanks >>
Hello e-pie, I prefer all.
Thanks. But no need for modesty, you should really refer to @lbix.
A study on Riemann-Christoffel tensor isn't complete without a physical meaning of the equations which I cleary lack and thus have created a huge hole in my physics knowledge. This is mostly because I did not have the time to go through physics at all for the last 6 to 7 years as I was working as a part time teacher for guiding maths olympiad enthusiasts(mostly teenagers between 14 to 16).
I will be free after 2 more years.
You mean like here in "http://web.mit.edu/klmitch/classes/8.033/Schwarzschild.pdf"? Here, also, I got a different value than what it is expected. May be I am wrong. I had inserted all values for Riemann curvature components at pp.9 with the derivative of Φ and Λ as $$\frac{M}{r(r-2M)}$$ and $$-\frac{M}{r(r-2M)}$$ for outside or vacuum solution respectively. I got $$\frac{2M}{r^3-2Mr^2}$$ for $${R^t}_{rtr}$$ and $$-\frac{M}{r}$$ for $${R^t}_{\theta t \theta}$$.
The Ricci Tensor components also result in zeros (in the document attached above).
My link isn't sufficient. Can I give a direct link google?
Of course.
Presumably you are. It's a little difficult to know since you haven't said what values you got. You can use LaTeX to insert formulas in posts - see https://www.physicsforums.com/help/latexhelp/ for details of how to make this work, and quote my post to see how I did the index placement if you aren't familiar with LaTeX.
Yes, they should do so.
Of course.
I asked the concerned mentor.
I have made the corrections with my last post. Please review it once.
The rendered equations are still not visible. Use the preview button
Thanks.
I hope you could give me the http link by directly copying.
You need two $ signs or two # signs to delimit LaTeX, not one.
You mean like here in "http://web.mit.edu/klmitch/classes/8.033/Schwarzschild.pdf"? Here, also, I got a different value than what it is expected. May be I am wrong. I had inserted all values for Riemann curvature components at pp.9 with the derivative of Φ and Λ as $$\frac{M}{r(r-2M)}$$ and $$-\frac{M}{r(r-2M)}$$ for outside or vacuum solution respectively. I got $$\frac{2M}{r^3-2Mr^2}$$ for $${R^t}_{rtr}$$ and $$-frac{M}{r}$$ for $${R^t}_{\theta t \theta}$$.
This is your #11, with LaTeX delimiters corrected.
$\frac{M}{r(r-2M)}$
Add one $ each start and end. Use the preview button.
You mean the file I uploaded. I cannot unless a mod gives me permission. Maybe it was a copyright violation. So you have to wait until I clarify it via PM.
Yes I have corrected and have some questions for you. Please revisit the post again.
I agree about ##\Phi'## and ##\Lambda'## and the two components you've calculated, but there are twelve non-zero components of the Riemann in total (though only four six independent ones, I think). So you have a bit more work to do...
Ibix said:
I agree about ##\Phi'## and ##\Lambda'## and the two components you've calculated, but there are twelve non-zero components of the Riemann in total (though only four independent ones, I think). So you have a bit more work to do...
But there are only six components listed both in the above document and in the MTW of which I have calculated only two those are different than what they should be. Am I wrong? And I am in search of getting the same values listed in MTW.
@Ibix Aren't there 36 in 4d Space. This condition shows that the all the components whose 1st and 2nd or 3rd 4th indices are equal must be zero. Therefore square of 4C2=36.
MTW says on page 821 that there are other non-zero components obtainable by symmetries of the Riemann. I'm not sure about the all-lower-index Riemann that they are using, but there are twelve non-zero components in the (1,3) form you seem to be using (although on a re-read I'm not certain you have the lower indices in the order I expected - I think what you've called ##R^t{}_{rtr}## is usually ##R^t{}_{rrt}##, although it's possible I've got lost in the different notations used by different sources).
If arranged in a 6 x 6 matrix, there are still 21 independent components.
e-pie said:
@Ibix Aren't there 36 in 4d Space. This condition shows that the all the components whose 1st and 2nd or 3rd 4th indices are equal must be zero. Therefore square of 4C2=36.View attachment 229214
Most of them are zero in the Schwarzschild metric. It's only the remaining ones we care about. And there are twenty independent components in general: http://mathworld.wolfram.com/RiemannTensor.html
  • #31
Bianchi Identity?
4C4=1 21-1=20 ?
  • #33
To put this in a slightly different way: The spherical symmetry of the Schwarzschild spacetime means additional constraints on the components of the Riemann tensor. For the general N-dimensional case (without symmetries in the spacetime) is ##N^2(N^2-1)/12##, which follows from first checking the number of components allowed by the symmetries of the tensor and then removing some due to the Bianchi identity.
Likes Bishal Banjara and Ibix
  • #34
Yeah I got the point and answer here at https://physics.stackexchange.com/q...he-riemann-tensor-of-the-schwarzschild-metric
  • #35
Orodruin said:
To put this in a slightly different way: The spherical symmetry of the Schwarzschild spacetime means additional constraints on the components of the Riemann tensor. For the general N-dimensional case (without symmetries in the spacetime) is N2(N2−1)/12N2(N2−1)/12N^2(N^2-1)/12, which follows from first checking the number of components allowed by the symmetries of the tensor and then removing some due to the Bianchi identity.
That means, ... Detail not shown after using Bianchi and swapping
Rnmlj + Rnljm + Rnjml= - Rnmjl - Rnlmj - Rnjlm = 0
Therfore 20 components and further restriction give 12 independent.
  • #36
Hello lbix,
Just take it as my innocence and reply me, does the Kruskal-Szekeres coordinate transformation passes all the test of Schwarzschild Solution like light bent, mercury precision,...?
  • #37
Hello lbix,
Predictions are not coordinate dependent and the KS coordinates are just a different set of coordinates on the Schwarzschild spacetime. Perhaps a result of how it is often being taught with emphasis on coordinates and coordinate transformations, students often make this mental mistake. Bottom line: The spacetime does not change just because you change coordinates.
Likes rrogers
  • #38
Hello Orodruin,
I argue that if we change the coordinate there will be the change in Riemann curvature tensor (like at the case of the event horizon), doesn't this effect on the line element itself. Do we have some sortie reference in that regard? Thank you for your response.
Likes rrogers
  • #39
No, this is wrong. Vectors and tensors do not change when you change coordinates - their components change but that is only in response to a change in the basis used to describe them. In the case of the Schwarzschild spacetime, the Schwarzschild coordinates are singular at ##r = 2MG## and therefore not a good basis to use, meaning that you cannot use it properly at that coordinate.
  • #40
Hello Orodruin,
Remember that these equations are a description of "real" things. It turns out this description is a little complicated, but very accurately describes what we observe in intermediate range physics: colliding stars, black holes...
Likes kent davidge
  • #41
If so, then let us assume that the $$g_{tt}$$ and $$g_{rr}$$ being like in the form $$(1+2GM/r)$$ and $$(1+2GM/r)^{-1}$$ respectively. Do such tests remain independent again where we have no singularity at r=2GM?
  • #42
I am sorry, but it is completely unclear what "tests" you are referring to. What you have quoted here are the components of the metric in Schwarzschild coordinates. In a different coordinate system, those components will be different, but the metric itself is still the same metric.
  • #43
I mean the precision of Mercury, light bent,..and so on. Does this form of metrics still don't effect on these tests?
  • #44
The form of the metric does not matter, because the theory is about the manifold (space-time). The tests are meant to check that gravity is the change in the underlying mesh of space-time. The form of tensors, like the metric, you need for doing calculations. The same way we represent a vector as an arrow and we do not need to know about any coordinate system nor what its components are. But if you are to solve a problem requesting you to give, say, a speed, then you need to go into numbers. Then you need to know the components.
So for actually computing the tests of General Relativity, you need to know the components, which is done through a coordinate system. But they do not affect the tests in the sense you seem to think.
  • #45
kent davidge said:
The form of the metric does not matter, because the theory is about the manifold (space-time). The tests are meant to check that gravity affects space-time, affecting the "underlying mesh". The form of tensors, like the metric, you need for doing calculations. The same way we represent a vector as an arrow and we do not need to know about any coordinate system nor what its components are. But if you are to solve a problem requesting you to give, say, a speed, then you need to go into numbers. Then you need to know the components.
But if you are to solve a problem requesting you to give, say, a speed, then you need to go into numbers. Then you need to know the components. Don't these tests are the results of respective components and get affected due to such change in metric values?
  • #46
Don't these tests are the results of respective components?
No, think of it this way: you are at the entrance of a tunnel, the result is at the exit and the components are the tunnel. They are a path linking you to the result, but the result is out there whether or not you have the components. Therefore they cannot affect the results.
  • #47
This means that it is alike the coordinate transformation as like the KS. Am I right?
  • #48
Stated a little differently: The numbers you use in all your intermediate computations will, in general, depend on your choice of coordinates. However, regardless of the coordinate system, the numbers will in the end conspire to produce the same result.
  • #49
This means I could reach the top hill from all sides around (conceptually linking the least action principle).
My doubts are clear now. Thank you very much for all of you!
Likes kent davidge
  • #50
A concrete example would be the electric field from a point charge at the origin of a Cartesian coordinate system. The field at (x,y,z) in the matching coordinate basis is ##E^\mu=(E_0x/r^3,E_0y/r^3,E_0z/r^3)##. But you can switch to spherical polar coordinates and say that the field at ##(r,\theta,\phi)## is ##E^{\mu'}=(E_0/r^2,0,0)## in that coordinate basis. The electric field vector at any point is the same in either system - only the representation has changed. Similar remarks apply to one-forms and higher rank tensors.
When you make a measurement, it'll turn out that what you actually measure is a Lorentz scalar (necessarily, or your instrument readings would be coordinate dependent). For example, one thing you could do to measure the electric field is have a test charge attached to a spring and constrained to move in one dimension. What you actually measure is the inner product of the Lorentz force and the direction of (constrained) motion, which is a scalar. If you let that direction be parallel to a basis vector then this is equal to the matching component of the electric field vector expressed in that basis multiplied by the charge. But you are deriving the component from the scalar you measured, and if you make three linearly independent measurements at a point you can express the result in any basis you like.
