How to Calculate Total Resistance in a Box-Formation Resistor Network?
The discussion focuses on calculating the total resistance in a box-formation resistor network consisting of 12 equal resistors. The key equations utilized are the series resistance formula (R = r1 + r2 + ... + ri) and the parallel resistance formula (1/R = 1/r1 + 1/r2 + ... + 1/ri). The application of Kirchhoff's laws is emphasized for analyzing current distribution across nodes. The proposed method involves simplifying the network by treating groups of resistors in parallel, ultimately leading to a total resistance calculation.
  • Understanding of series and parallel resistor configurations
  • Familiarity with Kirchhoff's laws
  • Basic circuit analysis techniques
  • Knowledge of voltage sources and current flow in circuits
  • Study advanced applications of Kirchhoff's laws in complex circuits
  • Learn about equivalent resistance in more intricate resistor networks
  • Explore simulation tools like LTspice for circuit analysis
  • Investigate the impact of resistor values on total resistance in parallel and series combinations
Electrical engineering students, circuit designers, and hobbyists interested in understanding resistor networks and circuit analysis techniques.
AROD
I have a network of resistors in a box-formation. There is 1 resistor of equal resistance in between every corner of the box, so 12 in total.
In series R = r1 + r2 + ... ri
In parallel, 1/R = 1/r1 + 1/r2 + ... 1/ri
I can't really draw a 2D analogous network due to the connections. I know kirchhof's rules must be applied somehow... that no current will flow between two points of equal potential difference, but not sure where that would be.
Just apply kirchhof law, that the sum of currents at node is zero. So first introduce some current in the circuit by applying a voltage source of 1 volt to make it easy. Then analyze every node to see how the currents are distributed in the branches.
first node brances to 3, each of those branch twice, 6 branches then converging on 3 nodes, which tnen go back to 1 node.
since all resistors are equal, can the 3 node to 3 node connection be just expressed as 3 parallel with 2 each? my reaction is to make each little group of 2 parallel, giving a total of 5/6 for the entire thing, but i don't know.
this is also then accounting for all of the resistors contributing. it looks to me like charge would flow through everything.
  • · Replies 23 ·
  • · Replies 60 ·
11K
  • · Replies 19 ·
