How to calculate weight of object swinging a radius?
  • Thread starter Thread starter dishguy55
    Radius Weight
To calculate the weight developed by a 20 lbs object swinging from a 30-inch arm, one must consider the forces acting on the object during circular motion. The discussion emphasizes the importance of angular velocity, with the formula w = 2π/t being relevant, where t is the period of rotation. The user also notes that RPM should be converted to seconds for accurate calculations. Understanding Newton's second law is crucial for relating the forces to the weight measured in pounds. Overall, the conversation focuses on the need for proper unit conversion and the application of physics principles to solve the problem.
dishguy55
20 lbs. on the end of a 30 inch arm. Dropping from 2oclock position to 5oclock position.
How much wieght will be developed if this was dropped on a scale measuring lbs.
I am unsure how to calculate this.
If there is a formula I can try to calculate myself.
I just don't know where to start.
Hi there...
Let me see if I get this straight:, by
...if this was dropped on a scale measuring lbs.
did you mean that at that juncture, on this sort of pendulum, the thread/rope(whatever) is suddenly cut, and the object is dropped on a weight measure?
If that's the case, then you must consider what sort of forces act upon an object moving in such a structure; Essentially(and this is quite a hint), you need to think about circular motion...
Give it a try, it's bound to work...
Good luck,
Daniel
Ok. i researched that and found this formula.
w=2*3.14/t.
w in my angular velocity. that is what i need to know.
t is the period for 1 rotation.
Is the rotation in rpm.
I know my rpm is 19.
If so then w would be .33
If my angular velocity is .33
How does that convert to lbs?
Well, let me simply rearrange what you wrote, if you don't mind...
You're correct in positing that: \omega = \frac{2\pi}{t}, Where t is the time of a single rotation(however, in SI units, this is ALWAYS measured in seconds); Therefore, RPMs won't do.
My advice is(based on my personal experience) is to try and convert any problem to metric units(SI based), and if the solution explicitly requires Imperial/non-standard representation, only then(after having the proper resolution), should you turn it back to whatever's necessary(but that's my opinion, and you're of course free to do what you're comfortable with).
As for those pesky Lbs, think about what a force suggests, its equation, and what do Lbs represent in this case(Newton's 2nd law would be helpful).
You're on the right track though,
Daniel
  • · Replies 44 ·
  • · Replies 28 ·
