How to correctly mark event B on the picture?
  • Context: Undergrad
  • Thread starter Thread starter Mike_bb
    Clock Photon Velocity
Mike_bb
Hello!
I have photon clock that moves to right side with velocity V.
In the first case events A and B are depicted on the picture on the top side:
In accordance with the Principle of Relativity I obtained second case.
But I can't mark event B in the second case on the bottom side. Where is event B located in this case?
Thanks!
I guess you describe the same events A and B from the viewpoint of two different frames: In the first frame (upper image), the light clock moves to the right, in the second frame (lower image) it moves to the left. If that's the case, then event B on the lower image is located in the middle of the left-bottom mirror where it meets the arrow.
It's difficult to know because you haven't described the experiment clearly. @Histspec's guess is reasonable and may be correct, but it's a guess.
You say the clock is moving to the right. Presumably that's in the top picture. Is it supposed to be moving to the left in the lower picture? That's what I would guess, but that's an unusual thing to do with a light clock since it doesn't really gain you anything. What's the extra quantity ##t_0## in the srcond diagram? How does it relate to anything else? Is the shading of the mirrors meant to be indicative of something? And what are events A and B supposed to be?
In particular, if you write down a description of A and B I suspect you will answer your own question.
In the top picture clock is moving to right. But in the lower picture clock is rest. (In accordance with Principle of Relativity)
$$c^2\Delta t^2-\Delta x^2 = c^2\Delta t_0^2-\Delta x'^2$$
Then, in the second picture there is no velocity ##v## and no moving clock. Event A occurs directly above event B.
These equality for first and second picture:
$$c^2\Delta t_0^2-\Delta x'^2 = c^2\Delta t^2-\Delta x^2$$
In accordance with Principle of Relativity we have that first frame and second frame are reversable. It's shown on the first and second picture.
Thanks. It's right!
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 115 ·
10K
  • · Replies 25 ·
  • · Replies 40 ·
  • · Replies 34 ·
  • · Replies 59 ·
