How to Create 1% Iron Solution - Step by Step Guide
  • Thread starter Thread starter lesieux
    Iron
8 replies · 5K views
lesieux
1% iron solution??
Dissolve 1.70g of iron III chloride in 99 ml of distilled water. Mix well and label 1% iron.
I've tried to check the value of the iron percentage but I don't succeed.
First I've tried to find out the number of mole of FeCl3,6H2O (M=270g.mol-1) in 1.70 g and found the mass of iron 0.352 g then divide this mass by the total mass (1,7+99), but it doesn't work. Could anyone help me? Thanks in advance.
You are going to determine iron in what form? You are going to report iron as Fe or Fe2O3 or FeCl3? I've got a feeling that you won't be reporting iron as FeCl3. Find out the form you need and ratio the molecular wt to that of FeCl3.
I'm guessing that it will be something like 1.7.
That could be accidental, but to prepare 1% w/w FeCl3 solution you need to dissolve 1.7 g (more precisely 1.68 g) of FeCl3.6H2O in appropriate amount of water.
I wrote concentration calculator just to be able to check such things on the fly...
I'm sorry to ask you this question.
It may be obvious but as i didn't succeed.
Would you mind showing me the calculation?
Thanks in advance.
Basically you have to calculate what is mass of FeCl3 in 1.7g FeCl3.6H3O. Start calculating their molar masses. 1 mole of FeCl3.6H3O contains how many moles of FeCl3?
Assume that the FeCl3 is anhydrous.
You are asked to label it 0.10 M, not 1%, right? If that is the case, then you are on the right track. Be sure to carefully weigh the FeCl3 and label it accordingly. You might not need to measure it out to three or four decimals, but you should do so in your calculations.
Remember that moles = grams/formula wt. and that concentration (M) = moles/volume(L)
