How to create a sound-activate switch control a linear Actuator.
The discussion focuses on creating a sound-activated linear actuator to open blinds with an alarm. Key concerns include whether a loud alarm clock will trigger the switch and the possibility of incorporating a toggle switch to close the blinds after they have been opened. Clarification is sought on the sequence of actions: blinds should only open when the alarm sounds, and then close afterward. The conversation emphasizes the need for precise control to avoid unintended activation. Overall, the goal is to design a reliable system for automated blind operation in response to an alarm.
michael19g
I am trying to make a sound activated linear actuator to open blinds when my alarm goes off. There are a couple concerns I have; Will the switch be triggered by a loud alarm clock? and would there be a way to have another switch to close the blinds once they have been opened, something like a toggle switch or button? I would appreciate any other suggestions
Let me understand what you want. When your alarm goes on you want nothing to happen until the alarm goes off and then you want to open the blinds. Once the blinds are fully open, you want your blinds to close again. Is that correct? If the blinds don't open until the alarm goes off, why would you be worried about a loud alarm going on triggering them to open?
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 49 ·
  • · Replies 25 ·
