How to Design an Egg Crash Landing Device Using Limited Materials
  • Thread starter Thread starter oo-FadedMaximus
    Crash Device Egg
The discussion centers on designing a crash landing device to protect an egg dropped from various heights, using only 1 meter of masking tape and 10 sheets of computer paper. Participants suggest various construction techniques, such as creating paper beams and using crumpled paper for cushioning. Ideas include building a crushable landing pad and utilizing structures like a star-shaped support or a mattress-like arrangement with tape. The emphasis is on slowing the egg's descent to minimize the impact force upon landing. Overall, the goal is to creatively use the limited materials to ensure the egg remains intact after the drop.
oo-FadedMaximus
Hey, I need to design an egg crash landing device in order to protect an egg that is being dropped from various heights.
The catch is I am only allowed to use 1 metre of masking tape and 10 sheets of computer paper.
If anybody has done this experiment before or have any suggestions, I would love to hear them thanks!
First, boil the egg.
I wish - although that's against the rules.
Oh well... that's the extent of my expertise.
Take a sheet of paper and write on it "Please deliver a mattress to <..enter address here..>". Take the tape and tape this message to the door of a mattress deleivery place.
Just crumble up the paper tape it to the egg then make a bigger sphere with the tape on the outside of the crumpled paper.
-Tape
=paper
-Tape
Oegg
-Tape
=paper
-Tape
Nothing is allowed to touch the egg, it has to sit free standing on the ground and the egg will be dropped onto it. by the way, i love the matress idea, very humorous.
Lookup some of the discussions on how to build a 4 foot tower out of a single sheet of computer paper plus tape.
Adapt the construction techniques for the tower to build a crushable "landing pad" instead of a tower.
Key construction elements will be paper beams, consisting of 1 (or possibly 2) folded strips of paper. Joining two strips with slits on the end will probably produce a stronger beam, this is a technique I never tried. See the "paper tower" article for more ideas - if you can find it. It was on this website once, and I think I posted to it, so if you try you should be able to find it with the sites "search" facility.
I'm not sure of the optimum design of the landing pad - I would suggest something like Buckminister Fuller's octet truss, which could be produced from a mass of constant-length paper structual "beams" - or possibly there might be a better construction technique than this by making entire triangles?
http://www.tabletoptelephone.com/~hopspage/Fuller.html
Egg Drop
OK, its quite simple , i figured this out with a little help of some of the other things people posted. I have the same project (a yard of tape, 5 sheets of paper). And i figured out the you just neeed to make constant supports. Like i took 3 pieces of skinny paper, like i cut them out of real paper, slim peices, folded them in half; and corossed three of them to make a star looking thing. Then i just taped both of them to the egg, and put a piece of a tube filled with crumbled pieces of paper with each end. You can drop it from a very far height usuing this method, because even if the star crossed supports didnt work, you still have the crumbled pieces of paper. Hope i helped :cool:
Try putting the sheets flat on top of each other, and use the tape to attach them as tight as possible to the cement.
:smile: Gotta love those smart-ass remarks... :smile:
Seriously though, perhaps you could make small loops of masking tape and then you could put them between the layers of paper. It would make a good "mattress".
The only problem with that is that the tape would be absorbing the energy, while the paper would transfer the majority of energy.
Think of it like this: If you have 2 sheets of paper on top of another, and you have little masking tape springs, what if the egg doesn't hit a piece of the paper that isn't supported by the tape? The egg won't decelerate as quickly.
The main goal here is to slow the velocity of the egg. If you could build a tower of some sort, then have the catching mechanism in the middle, it might work.
Here's the demonstration my HS physics teacher did:
He took an egg and threw it, point blank, as hard as he could, into a bedsheet. The egg didn't break.
The moral is that it's not the fall that hurts, but the sudden stop. So, your goal is to make the stop less sudden. There are many ways to do this.
