How to determine heat from resistance?
  • Context: Undergrad
  • Thread starter Thread starter Thundagere
    Heat Resistance
The thermal energy released from electricity flowing through a wire can be determined using the formula Q = I²RT, where I is the current, R is the resistance, and T is the time. This formula derives from the fundamental physics principle that work done on a unit charge manifests as heat energy due to resistance in the wire. Additionally, the resistance can be expressed as R = k(l/a), where k is resistivity, l is the length of the wire, and a is the cross-sectional area.
  • Understanding of Ohm's Law
  • Familiarity with basic electrical concepts (current, resistance, voltage)
  • Knowledge of thermal energy principles
  • Basic algebra for manipulating formulas
  • Research the derivation of Ohm's Law and its applications
  • Learn about resistivity and its dependence on material properties
  • Explore the relationship between electrical energy and thermal energy
  • Investigate practical applications of thermal energy calculations in electrical engineering
Electrical engineers, physics students, and anyone interested in understanding the relationship between electrical resistance and thermal energy generation in conductive materials.
Thundagere
Is there a formula of some sorts that can determine the thermal energy released from electricity flowing through a wire, knowing the wire's resistance?
Yes , there is formula. You can even derive it logically. You can do it! Work done=Energy manifested is a basic logical equation in fundamental physics.
Thermal energy released from wire due to its heating = I2RT
Thermal energy is not released from electricity. It is released due to resistance in a wire because work is done on per unit charge to move it through certain displacement in a wire. On moving a unit charge it faces obstruction or friction of wire. This work done is manifested in form of heat energy in a wire.
You know ,
V=W/Q
W=VQ
So Heat energy released or work done by wire :
Thermal energy released from wire due to its heating = VQ
Thermal energy released from wire due to its heating = IR x IT
Where I is current flowing in wire , R is resistance and T is time.
R=k l/a
a is area of cross section in a wire and l is length of wire.
k is (rho) or resistivity in a wire.
Thermal energy released from wire due to its heating = k I2 T l/a
  • · Replies 57 ·
13K
  • · Replies 16 ·
  • · Replies 105 ·
11K
