How to determine if a set is a semiring or a ring?
The discussion centers on the mathematical properties of the set ##\mathcal{A}##, derived from a finite nonempty set ##E##, specifically demonstrating that ##\mathcal{A} = \bigcup_{n=0}^\infty \mathcal{A}_n## forms a semiring but not a ring when the cardinality of ##E## exceeds 1. The conditions for a semiring are satisfied, including the presence of the empty set, closure under intersection, and the ability to express differences as finite unions of disjoint sets. However, ##\mathcal{A}## fails to meet the closure requirement for set difference, which is essential for it to be classified as a ring.
  • Understanding of finite sets and sequences
  • Familiarity with the concepts of semirings and rings in set theory
  • Knowledge of set operations such as union, intersection, and set difference
  • Basic mathematical notation and logic
  • Study the properties of semirings and rings in abstract algebra
  • Explore examples of set operations and their implications in set theory
  • Learn about cardinality and its effects on set classifications
  • Investigate the implications of closure properties in algebraic structures
Mathematicians, students of abstract algebra, and anyone interested in the properties of sets and their classifications in mathematical structures.
WMDhamnekar
MHB
Let E be a finite nonempty set and let ## \Omega := E^{\mathbb{N}}##be the set of all E-valued
sequences ##\omega = (\omega_n)_{n\in \mathbb{N}}F##or any ## \omega_1, \dots,\omega_n \in E ## Let
##[\omega_1, \dots,\omega_n]= \{\omega^, \in \Omega : \omega^,_i = \omega_i \forall i =1,\dots,n \}##
be the set of all sequences whose first n values are ##\omega_1,\dots, \omega_n##. Let ##\mathcal{A}_0 =\{\emptyset\}## for ##n\in \mathbb{N}## define
##\mathcal{A}_n :=\{[\omega_1,\dots,\omega_n] : \omega_1,\dots, \omega_n \in E\}##.
Hence show that ##\mathcal{A}= \bigcup_{n=0}^\infty \mathcal{A}_n## is a semiring but is not a ring if (#E >1).
My answer:
Let's consider an example where ##E = \{0,1\}## and ##\Omega = E^{\mathbb{N}}## is the set of all E-valued sequences. For any ##\omega_1,\dots,\omega_n \in E##, we have
##[\omega_1,\dots,\omega_n] = \{\omega \in \Omega : \omega_i = \omega_i \forall i = 1,\dots,n\} ##which is the set of all sequences whose first n values are ##\omega_1,\dots,\omega_n##. Let ##\mathcal{A}_0 = \{\emptyset\}## and for ##n \in \mathbb{N}## define
##\mathcal{A}_n := \{[\omega_1,\dots,\omega_n] : \omega_1,\dots,\omega_n \in E\}.##
Hence ##\mathcal{A} = \bigcup_{n=0}^\infty \mathcal{A}_n## is a semiring but not a ring if # E > 1.
To see why ##\mathcal{A}## is a semiring, let's verify that it satisfies the three conditions for a semiring. First, it contains the empty set because ##\mathcal{A}_0 = \{\emptyset\}## and ## \mathcal{A} = \bigcup_{n=0}^\infty \mathcal{A}_n##. Second, for any two sets ##A,B \in \mathcal{A}##, their difference ##B \setminus A## is a finite union of mutually disjoint sets in ##\mathcal{A}.## For example, let A = [0] and B = [1], then ## B \setminus A = [1] ##, which is ##\in \mathcal{A}.## Third, ##\mathcal{A}## is closed under intersection. For example, let ##A = [0]## and ## B = [1]##, then ## A \cap B = \emptyset ##, which is in ##\mathcal{A}##.
However, ##\mathcal{A}## is not a ring because it does not satisfy all three conditions for a ring. Specifically, it does not satisfy condition (ii) for a ring, which requires that ##\mathcal{A}## be closed under set difference. For example, let A = [0,0] and B = [0,1], then ## B \setminus A = [0,1] \setminus [0,0] = [0,1]##, which is not in ##\mathcal{A}##.
I hope this example helps to illustrate why##\mathcal{A}## is a semiring but not a ring if the cardinality of E is greater than 1. Is this answer correct?
In order to determine if the set is a semiring you first need to specify exactly what are the addition and multiplication operations.
It refers to a semi-ring of sets, defined here, not a semi-ring in the algebraic sense.
That is not correct. [0,1] is indeed an element of ##\mathcal A## so this example does not demonstrate non-closure. That example was never going to work because you are subtracting from a set another set that has no overlap with it, so the subtraction doesn't change the set. I don't want to give too much away so I'll keep the hint general. Why not instead try taking the union of two sets to give a set that can't be expressed as any [a, b, ..., c]? Since the whole structure is based on fixing the first n components of a sequence, try choosing two sets that are the same in their first component (##\omega_1##), but differ in their second (##\omega_2##). That should give you a set of all sequences with a fixed second component but arbitrary first component, and that might not correspond to any equivalence class in ##\mathcal A##.
  • · Replies 27 ·
