How to Determine the Axis of Rotation
To determine the rotational kinetic energy of a system with two different masses attached to a massless bar and springs, the choice of axis for rotation is flexible and should be based on convenience. The total kinetic energy can be calculated by summing the kinetic energies of the individual masses, regardless of the chosen axis. The axis affects the distribution of kinetic energy into rotational and linear components but does not change the total kinetic energy. For calculations, it is beneficial to select an axis where the moment of inertia is known. Understanding the system's dynamics through Lagrangian mechanics can also aid in analyzing the potential and kinetic energies involved.
Diracobama2181
Let's say I have a massless bar of length ##l## with two different masses, ##m_1## and ##m_2##. Suppose an identical spring is attached to each individual mass, with the other end being attached to the ceiling. How would I go about determining the rotational kinetic energy of the system. Do I choose the axis about the center or the center of mass?
Diracobama2181 said:
Summary: When determining the kinetic energy of a rotating system, which point should I use as an axis to determine rotation kinetic energy.
If your goal is to determine the kinetic energy of the system, there is no need to bother with an axis of rotation. You have two masses. Add up their kinetic energies.
The chosen axis merely determines how much of the kinetic energy is considered "rotational", and how much "linear". Their sum (total KE) won't change.
You should choose an axis which is most convenient. For example, the one for which you know the moment of inertia, which is needed for the rotational KE calculation:
https://en.wikipedia.org/wiki/Rotational_energy
Likes jbriggs444
We can assume a flat motion system. Then we have 3 independent variables in the context of an inertial coordinate system : (x,y) for the position of the center of masses and φ for the bar's angle. From this information you can calculate the potential energy due to gravity an due to the strings and complete the Lagrangian as L=KineticEnergy-PotentialEnergy; where KineticEnergy is the sum of the kinetic energy of the center of masses plus rotational energy relative to the center of masses = 1/2 I (dφ/dt)^2 and I= moment of inertia relative to the center of masses.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 21 ·
