How to Determine the Change in Entropy of a Monoatomic Ideal Gas?
  • Thread starter Thread starter chocolatepie
    Change Entropy
The discussion revolves around determining the change in entropy (ΔS) of a monoatomic ideal gas undergoing expansion and temperature change. Participants explore relevant equations and concepts related to thermodynamics, particularly focusing on the assumptions regarding pressure and the calculations involved in the process.
  • Homework-related, Technical explanation, Exploratory
  • One participant presents a homework problem involving a monoatomic ideal gas expanding from 0.500L to 1.00L while increasing temperature from 298K to 373K, seeking to calculate the change in entropy.
  • Another participant suggests that pressure remains constant during the process, which influences the choice of equations for calculating ΔS.
  • There is a discussion about the correct values for molar heat capacities, with some participants correcting earlier claims about the heat capacity of a monoatomic ideal gas.
  • One participant expresses confusion about how to determine the number of moles and which values to use from the initial and final states of the gas.
  • Another participant introduces a formula for ΔS that incorporates both temperature and volume changes, which is noted as applicable for ideal gases.
  • Participants discuss the derivation of the entropy change formula, with one providing a detailed explanation of how it is derived from fundamental thermodynamic principles.
  • There is acknowledgment of confusion regarding the applicability of certain equations, particularly in relation to whether the process is isothermal or not.
Participants express differing views on whether the pressure remains constant during the process, and there is no consensus on the correct approach to calculating the change in entropy. Multiple competing views and uncertainties about the correct application of formulas persist throughout the discussion.
Participants note limitations in their understanding of the relevant equations and the assumptions made regarding the process conditions, such as pressure and temperature. Some calculations rely on assumptions that may not hold true for the described process.
chocolatepie
A monoatomic ideal gas is initially trapped in a 0.500L container at 298K and 100kPa. The sample is then allowed to expand to 1.00L and the temperature is increased to 373K. Determine change of the entropy (ΔS)
ΔS = ∫(T1 to T2) dqrev/T
Is the pressure constant?
Thank you for start replying my question. I REALLY appreciate it!
Ok. what I would do is to assume that pressure is constant, so I would use the formula I posted earlier.
C p,m = 3/2R
C p = 3/2R x change in mole (determined by PΔV=ΔnRΔT)
which would give me 0.9989 J/K
Then I would find the change of the entropy by integrating and it gave me:
ΔS = 3/2R (ln373-ln298)
= 2.8 J/K
Yes?
Hmm, you've got C p,m wrong (check the table).
I'm afraid there is no change in mole, but you do need to calculate the number of moles.
How did you get that formula?
Uh.. I wrote 3/2R because I was using the equipartition theorem. Since the monoatomic ideal gas does not have neither rotational nor transitional energy, 3/2RT. Then I sub this into heat capacity formula where T would get cancelled.
I am not even sure if I am doing this question right.. confused..
Oh, you're doing the question right.
There's just some minor stuff to take care of...
Let's start with the proper relevant formulas, which you seem to have left out.
You should have:
1. PV=nRT for an ideal gas.
2. Cv,m = (3/2)R for a monatomic ideal gas (molar heat capacity at constant volume).
3. Cp,m = (5/2)R for a monatomic ideal gas (molar heat capacity at constant pressure).
4. ΔS = Cp,m ln(T2 / T1) for 1 mole of an ideal gas at constant pressure.
See what I mean?
You should be able to find these on the wiki page I mentioned.
From (1) you can calculate the number of moles n...
Oh OK. I see what you mean now :redface:
But when determining the number of mole using PV=nRT, how do I know which T or which V I need to use? I have 2 values (for example, V1 and V2, etc). This is actually why I used the change (Δ).
Hmm, let's organize this a bit:
Darn! I'm just noticing that the process is probably not at constant pressure!
I'll have to think about that.
[tex]\begin{array}{| c | c | c |}<br /> \hline \\<br /> & \textrm{Before (1)} & \textrm{After (2)} \\<br /> \hline \\<br /> V & 0.500 \textrm{ L} & 1.00 \textrm{ L} \\<br /> T & 298 \textrm{ K} & 373 \textrm{ K} \\<br /> P & 100 \textrm{ kPa} & ? \\<br /> n & ? & ? \\<br /> S & S_1 & S_2, \Delta S = ? \\<br /> \hline<br /> \end{array}[/tex]
Can you fill in the question marks?
And I'll bring in a new formula (always true for an ideal gas):
[tex]\Delta S = n C_{v,m} \ln{T_2 \over T_1} + n R \ln{V_2 \over V_1}[/tex]
Whoa!
I got:
n= 0.02 for both initial and final
P2 = 62 kPa
ΔS = 0.12 J/K
However, I did not learn that formula.. I've seen the first and second part of the equation separately but not together like that. Shouldn't I use the second part of the equation for the reversible isothermal expansion? This was not isothermal though?
chocolatepie said:
Whoa!
I got:
P2 = 62 kPa
ΔS = 0.12 J/K
Looks good!
Ah well, I was looking for a general equation, but couldn't find it quickly enough, so I derived it myself.
It's probably on the internet somewhere.
Here's the derivation if you're interested.
[tex]\def\d{\textrm{ d}}[/tex]
From [itex]\d U=T \d S - P \d V[/itex] (always true!) we find:
[tex]\d S = {\d U \over T} + {P \d V \over T}[/tex]
With [itex]U = n C_{v,m} T[/itex]:
[tex]\d S = {n C_{v,m} \d T \over T} + {P \d V \over T}[/tex]
With [itex]P V = n R T[/itex] we also have [itex]{P \over T} = {n R \over V}[/itex] implying:
[tex]\d S = {n C_{v,m} \d T \over T} + {n R \d V \over V}[/tex]
Integrate, and we get:
[tex]\Delta S = n C_{v,m} \ln {T_2 \over T_1} + n R \ln {V_2 \over V_1}[/tex]
Thank you so much for your help!
I looked through my notes, and I realized that I actually had that formula LOL.
Anyway, thank you again!
Take care! :smile:
  • · Replies 60 ·
11K
17K
