How to draw pulley system diagram to find the relationship between two objects?
To find the relationship between the accelerations of two blocks in a pulley system, it's essential to correctly define the directions of motion. The correct relationship is 3aA = 2aB, indicating that as block A accelerates downward, block B accelerates to the left. It's crucial to align the signs of the accelerations with the defined directions of movement to avoid confusion. Understanding the motion as one-dimensional along the thread simplifies the analysis, as the actual orientation of the motion does not affect the relationship. Properly drawing the diagram and assigning directions to the displacements will lead to accurate results.
theBEAST
Here is the diagram and I need to find a relationship between the acceleration in block A and the acceleration in block B.
http://dl.dropbox.com/u/64325990/HW%20Pictures/datum2.PNG
Here is my diagram, which is wrong:
http://dl.dropbox.com/u/64325990/HW%20Pictures/Photo%202012-04-08%209%2039%2025%20PM.jpg
It is wrong in that there shouldn't be a negative sign in front of aB. Instead 3aA=2aB is the correct answer. However I do not know how to derive that answer and where to put my datum. I need help with the diagram, thanks!
If A moves downward B will move to the left and SB will decrease. You supposed aB in the direction of growing sA.ehild
I am still confused... So do you mean that with what I did, I can still get the correct answer? This is really confusing because one object is moving up/down while the other is left/right so I don't know how to set up the signs and how to define the directions.
I forgot to mention in the question that block A accelerates downwards and block B is to the left according to the question. I did the problem with 3a_A=-2a_B and I go the wrong answer. When I used 3a_A=2a_B I got the right answer.
OH I just had an epiphany, so are you saying that the way I drew my diagram would be wrong in that s_B is pointing to the right when it should be pointing to the left since the question tells me a_B is pointing to the left?
It depends what you mean on S. If it is the length of a piece of thread, 3SA+2SB =L is right. If it is displacement of a block in the "natural direction of moving) 3SA=2SB.
When the motion goes on along a thread, it can be considered one-dimensional. The actual direction (horizontal, vertical, along a slope... ) is irrelevant. Fit the direction of forces to the supposed direction of the accelerations.
ehild
ehild
This is what I am doing now and it has been working great so far! Thanks for your help!
You are welcome. :smile:
ehild
  • · Replies 66 ·
18K
10K
