How to enter command prompt with elevated priviledges at run?
  • Thread starter controlswhiz
8 replies · 4K views · last reply
controlswhiz
What the title says.
Windows 7 Start menu search for 'comman' with Command Prompt listed under Programs, its right-click context menu open showing Run as administrator highlighted, with numbered steps 1 to 4 and the title Run Command Prompt as Administrator.
just in case
step3: Right click where it says command prompt
Is there any keyword that I can add on the run command?
  • Windows Run dialog box with the text 'cmd' typed in the Open field, alongside OK, Cancel and Browse buttons.
I don't think so.
Can't you just put a shortcut on the desktop(If you find it difficult to use start menu.)?
It's in C:\Windows\System32 ... Name is cmd.exe
  1. Find it
  2. Right click on it
  3. Hover mouse over "Send to"
  4. Choose "Desktop(Create shortcut)"
Then you can simply run it as an administrator by right clicking on the shortcut
Hey Routaran, what kind of font are you using?
@adjacent: the font in the image? I have no idea, I shamelessly googled and posted an image from elsewhere on the internet as if it were my own. Sh*t, isn't that something you get hit with the banning stick for?
I think the person who made that image had shadows turned on for their text.
@controlswhiz: I don't think so either. the "-n" or "/help" options you enter after the file name are arguments you pass to the program that is being run. These are not interpreted by windows at all, they are specifically used the program in question. You need to tell windows to run a program elevated, not the program.
So, you have to launch the program by using the right click menu "Run as administrator" or use the method that adjacent posted.
I would add one extra step.
Right click on the shortcut>compatibility tab and check on "Run this program as an administrator"
this way you can simply double click the shortcut and it will run the command prompt elevated
image attached is an example of what you need to do.
  • Dwarf Fortress Properties dialog on the Compatibility tab, with the Run this program as an administrator checkbox under Privilege Level greyed out and a red arrow pointing to it.
You can try "runas" : http://superuser.com/questions/42537/is-there-any-sudo-command-for-windows
They say something like
Code:
runas /noprofile /user:Administrator cmd
In which case i'd make a "acmd.bat" file in your system32 directory with that in it, so you can just type acmd at the run box.
"Administrator" may need to be your user profile name if you have admin privs.
I usually just type "cmd" in the start search, and then ctrl-shift-enter to launch the selected program as an admin. No mouse use, funny settings, or extra shortcuts required.
I did not know about the Ctrl+Shift+Enter shortcut. Great tip!
