How to figure out the ratios in which elements combine
The discussion focuses on determining the ratios in which elements from period 2 combine with chlorine and oxygen. Key concepts include the importance of understanding 'valency' and the behavior of elements in forming compounds with neutral charges. Participants emphasize that elements typically bond either covalently or ionically, which influences the ratios of their combinations. A clear method involves analyzing electron sharing or transfer to achieve a stable compound.
  • Understanding of chemical valency
  • Knowledge of ionic and covalent bonding
  • Familiarity with electron configuration
  • Basic principles of chemical reactions
  • Research the concept of valency in detail
  • Study ionic and covalent bonding mechanisms
  • Learn how to write and balance chemical equations
  • Explore the periodic table's trends and element properties
High school chemistry students, educators teaching chemical bonding, and anyone interested in understanding elemental combinations and compound formation.
ryan001
I need to know is how to figure out the ratio's in which the elements in period 2 combine with
chlorine and oxygen i.e a method to solve the problem.
I 'm currently in 10th grade.
Thanks in advance I appreciate the help.
None that I know of
I have no idea where to start. I have tried adding and subtracting electrons, but that does not add up to the answers at the back of my textbook
I can't read your attachment but...
Are you familiar with the concept 'valency'?
Then, but I'd say in second place, there is some theory for it in terms of electrons.
Most elements will combine such that there is no net charge. Like epenguin said, learn about valency and determine whether the elements that combine with oxygen bond covalently or ionically. This will allow you to determine the ratio required for any two elements to share/(donate/receive) electrons to form a compound with neutral charge.
11K
  • · Replies 24 ·
