How to find a vector orthogonal to a line
To find a vector orthogonal to a line represented by a linear equation, one can derive it from the coefficients of the equation. For example, for the equations 3x + y = 5 and 2x - y = 4, the normal vectors are n1 = <3, 1> and n2 = <2, -1>. The angle between the two lines can be calculated using the dot product and the magnitudes of the vectors. Alternatively, one can find the direction vectors of the lines and use their slopes to determine the angle directly. Understanding these methods clarifies the relationship between the lines and their orthogonal vectors.
furqankaimkha
Hi
I have two (two dimentional) linear equations (in the plane). and i am required to find out the angle between them. I have found the solution somewhere.
the solution uses two vectors orthogal to the two lines.
The problem now i have is: How to determine those orthogonal vectors?
e.g: two equations are: 3x + y = 5 and 2x - y =4
Now the solution goes like this:
n1 = 3i + j and n2 = 2i - j.
Then the angle between them is found out by using Dot product. This is the required angle.
How did they determine n1 and n2?
Look at the coefficients of x and y in an equation and compare them to the corresponding normal vector.
I’m confused on your approach.
Do you know these facts about vectors, if so it should be fairly easy:
a dot b = a1b1 + a2b2 + ...
theta = cos-1( [a dot b]/[|a||b|])
the cross product gives you a normal vector
A line can be represented as: <x,y> = <a,b> + tv where (a,b) is on your line and v is the same direction as the line. v is easy to find: If A = (x1, y1) and B = (x2,y2) are both on your linen the v = <x1 - x2, y1 - y2>
How i would do your problem, find the direction vector of each line. Then use that property of the dot product i posted.
I think that you're thinking too hard, write the equations as y=mx+c, m is the tangent of the angle that the line makes with the x-axis. So to find the angle made by both of them, take the arctan of the gradient and then just subtract these two angles to get your answer.
As Hunt_Mat says, you can rewrite 3x + y = 5 and 2x - y =4 as y= -3x+ 5 and y= 2x- 4 seeing that the slopes are -3 and 2 respectively. I would NOT, however, take the arctan of each to find the angles! Remember the simplest introduction to slope: "rise/run". Slope -3 tells you "if x increases by 1 then y decreases by 3" which corresponds to the vector <1, -3>. Similarly, slope 2 tells you "if x increases by 1 then y increases by 2" which corresponds to the vector <1, 2>.
Those are NOT the vectors given because they are vectors in the direction of the lines, not orthogonal to them. But you can use the "dot product" as you suggest: if a vector orthogonal to <1, -3> is given by <a, b> then we must have <1, -3>.<a, b>= a- 3b= 0. From that, a= 3b so if we take b= 1, a= 3- an orthogonal vector is <3, 1>. Similarly, if <a, b> is orthogonal to <1, 2> we must have <1, 2>.<a, b>= a+2b= 0 or a= -2b. Taking b= 1, a= -2 so an orthogonal vector is <-2, 1>. Those are the two vectors you give.
However, if the original problem was to find the angle between the two lines, I cannot imagine why they have chosen to use orthogonal vectors! The simplest way to do it is to just use the angle in the direction of the lines, <1, -3> and <1, 2>. u\cdot v= |u||v|cos(\theta) which here gives
1(1)+ (-3)(2)= 1- 6= -5= \sqrt{1+ 9}\sqrt{1+ 4}cos(\theta)
= \sqrt{50}cos(\theta)= 5\sqrt{2} cos(\theta)[/itex].<br /> <br /> That is, cos(\theta)= \frac{-5}{5\sqrt{2}}= -\frac{1}{\sqrt{2}} and it should be easy to get the angle from that. Of course, if l and m are lines, l&#039; is perpendicular to l, m&#039; is perpendicular to m, then the angle between l&#039; and m&#039; is exactly the same as the angle between l and m. The two methods give the same answer- I just don&#039;t see why one should go to the trouble of finding the orthogonal vectors when it is not necessary.
Or what you could do, is calculate the point at which they intersect, call this point (x,y), choose a>x (you are free to choose a, it could be x+1 for example), and consider the point (a,2a-4). Construct the nornal to y=2x-4 at this point and exanine where this intersects the line y=-3x+5, call this point (c,d).
What you have done is created a right angled triangle from the two lines that you want to find the angle of intersection of. let l_1 be the distance from (x,y) to (a,2a-4) (you can compute this easily) and let l_2 be the distance from (a,2a-4) and (c,d), then is theta is the angle between the two lines, you know that:
<br /> \tan\theta =\frac{l_{1}}{l_{2}}<br />
This method is somewhat long winded but it avoids the use of vectors and is quite clear geometrically. Food for thought.
I thank all of you for your precious guidance. This topic is now very much clear to me now. Love you all.
  • · Replies 17 ·
