How to find Fuel consumption for 10 MW Gas Generator
To determine fuel consumption for a 10 MW biogas generator, it's essential to first identify the type of generator or power plant being used, as fuel efficiency varies significantly among diesel, gas turbines, and steam systems. Users are advised to consult manufacturer specifications and data sheets for specific fuel consumption figures. The discussion emphasizes the importance of selecting the appropriate generator based on fuel type and cooling systems, and suggests researching biogas technology and design principles for further insights. Additionally, participants recommend using online resources to find relevant information on biogas power generation. Understanding these factors will help accurately estimate the biogas required for generating the desired power output.
Goldisach
Hi
I am working on Bio Gas Project and I want to know calculations/Formulas to find out elements of Generator.
I am MBA students and i have to submit my project report with to start up new firm on renewable energy.
Please submit can share your knowledge to help me.
You should Google spec sheets for existing commercial projects. Try Capstone Microturbines for a start.
Often though, you look at the issue from the other direction: what is the fuel source and how much is available?
Goldisach said:
Hi
This is a very vague request. The term "generator" has multiple technical meanings. What kind of generator? Or is it an entire power generating plant which is fueled by biogas? If you use the biogas to run a diesel or gas turbine, you'll get a range of fuel consumption figures. Same if the biogas is burned in a boiler to make steam to generate power.
Goldisach said:
Hi
So you are showing no effort and asking us to do your homework for you?
Likes kevnst
Yes,Its an Power Generating plan which will function on Bio gas as fuel.
That means you want to say all parameters will be same for Disel or gas turbine and steam to generate power using Bio gas
It's not clear what you mean by the term "parameters" here. All we know for certain is that this plant is intended to generate 10 MW of power.
The fuel efficiency of various types of power plant (steam, diesel, gas turbine) differs quite a bit, so in order to estimate how much biogas you need to generate 10 MW of power, you need to find out what sort of numbers to expect for these different generating options.
You need to look at combined cycle alternatives, Google it.
you can find the fuel consumption in the data sheet or specs of your generator, the data sheet is available in the manufacturer of your generator.
so the first thing you need to do is to choose first your generator, google biogas generator there's a lot of company manufacturing it like GE, rolls royce, pratt and whitney etc.
theres a lot of genarator in the market, so you choose it based on your requirement like type of fuel, cooling system(water or air cooled), etc. I am talking here about electric generator fueled by biogas/methane.
with regards to steam power plant wherein you use boiler fuled by biogas, the same thing to do, choose your boiler first.
decide what system to go(boiler or generator), there a lot of consideration here to make it more efficient and economical
google "how to design a biogas plant"
Thanks a lot
I tried on Google "How to design a Bio gas Plant". I have not got any relevant information.
If you have any link please share.
Once again thanks for information
Thanks for sharing information
10,000 kwh is Complete unit energy consumption which i estimated.
Now all i have to find how much Bio gas required to generate 10 MW power and to find this i want to know how to find bio gas consumption per hour for any 10 MW generator.
