How to find KE and PE without mass
  • Thread starter Thread starter alex steve
    Mass
This discussion addresses the calculation of kinetic energy (KE) and potential energy (PE) for a simple pendulum without knowing the mass. The key takeaway is that when mass is not provided, one can derive symbolic results or use specific values, which are per-unit-mass values. The kinetic energy can be expressed as KE = (1/2) * inertia * omega^2, and potential energy can be represented as PE = g * Δh. By canceling mass terms in equations, one can simplify the analysis to specific energy values.
  • Understanding of basic physics concepts such as kinetic energy and potential energy
  • Familiarity with pendulum motion and angular velocity
  • Knowledge of the equations of motion in classical mechanics
  • Basic grasp of symbolic mathematics and unit analysis
  • Research the concept of specific energy values in physics
  • Learn about the moment of inertia and its calculation for different shapes
  • Explore the principles of energy conservation in mechanical systems
  • Study the derivation of energy equations in pendulum motion
Students in physics, particularly those studying mechanics, as well as educators and anyone interested in understanding energy calculations in systems without known mass values.
alex steve
I am working on Computational physics homework and it asks to find the kinetic and potential energy of a simple pendulum. My only issue is that i don't know how to solve it without mass.
It gives me :
theta (pendulum angle)
omega (pendulum angular Velocity)
t (time)
length (length of string)
dt (time step)
I was looking at the kinetic energy equation and maybe I need to use Inertia for where KE = (1/2) (inertia)(omega) ? but then how would i find inertia?
Any help would be appreciated.
Hi alex steve, Welcome to Physic Forums
Please be sure to retain and use the formatting template that is provided in the edit window when posting a question in the homework areas of the forums. This is a requirement of the forum rules.
If no mass or moment of inertia are provided then the best you can do is provide a symbolic result, or assume an arbitrary value of mass for the problem.
An alternative is to use "specific" values. A specific value is a per-unit-mass value. For example, one might say that the specific kinetic energy of some object is 20 Joules per kg. If the body turned out to have a mass of 1 kg then it would have a KE of 20 J. If it turned out to be 100 kg, then it would have 2000 J of KE. Specific values are handy in some areas where particular mass values aren't known or don't matter too much to the details of the problem. A case in point might be where one is equating a change in potential energy to a change in kinetic energy. Normally one would write something like ##M g Δh = 1/2 M v^2##. Note that the M's cancel on both sides. So you could just write it as ##g Δh = 1/2 v^2##.
##g Δh## would be the "specific potential energy, and ##v^2/2## would be the specific kinetic energy.
  • · Replies 21 ·
  • · Replies 42 ·
