How to Find Vector Angles and Differences?
  • Thread starter Thread starter realism877
    Sum Vectors
The discussion revolves around finding vector angles and differences, specifically concerning two vectors with given magnitudes but lacking direction. The original poster seeks clarification on how a solution involving a magnitude of 9 and an angle of 34 degrees was derived.
  • Participants question the completeness of the information provided, particularly the missing directional components of the vectors. There are inquiries about the correct interpretation of the vectors and how to add or find the difference between them. Some participants suggest using trigonometric methods, such as the law of sines or tangent functions, to find angles.
The discussion is active, with participants exploring various interpretations of the problem. Some have offered guidance on expressing vectors in terms of their components, while others are seeking clarification on how to determine angles and the implications of vector direction.
There is a noted lack of information regarding the direction of the vectors, which is essential for solving the problem. Participants are also considering the implications of placing one vector in the negative direction and how that affects angle calculations.
realism877
Vector a =8
vector b=15
the solution is 9 and theta is 34 degrees
I want to know how did they come up with that solution.
You are either missing information, or neglecting to post it.
A vector has a magnitude and a direction. What you posted for a and b has the magnitude part down, but is missing direction.
Is this all you were given?
(this will likely be moved -- but I'm not an admin so oh well for now)
Here is the image of the solution
realism877 said:
Vector a =8
vector b=15
Are you sure you wrote this correctly? Is this magnitude? The actual vector? Euclidean vectors have a magnitude and a direction. I guess you could have vectors in R1, where there's only two directions (positive and negative).
However, the presence of an angle and an incorrect magnitude suggest to me that this is not the case. You need to elaborate.
We have to find the magnitude and direction of the sum of vector A and B.
Ok, so how do you typically add vectors together?
Yes
And get the angle
Do I use the law of sines or just the pythogrean theorem?
I know how to get 9 as the solution. HOwever, I don't know how they got 34 degrees as a solution.
You need to express each vector in terms of x and y (or horizontal and vertical) components. You should have either been shown this in your class, or it would be in your textbook as well.
As gb7nash asked, how have you been shown, in your class, to add vectors?
I got how to add them, but how do I find the difference?
I need help finding the angles. How do I do that?
I know I have to put b in the negative direction. Which I did, but what is its angle? What is the angle of a?
tanθ = (y component of vector) divided by (x component of vector)
The angle of b will change by 180 degrees when you put it in the opposite direction.
From the figure you posted earlier, a points straight down. That would be either 270 degrees or -90 degrees with respect to the +x direction.
  • · Replies 18 ·
  • · Replies 26 ·
