How to get water in air tight container w/ other specifics
  • Context: Undergrad
  • Thread starter Thread starter speeddman
    Air Container Water
The discussion centers on maintaining constant air pressure in a sealed container while introducing water through a hose. Participants suggest using a self-regulating valve system to pre-pressurize the water supply, similar to scuba gear developed by Jacques Cousteau. A backflow preventer is recommended as a practical solution to prevent air from escaping up the hose. Additionally, the configuration of entry and exit hoses at the bottom of the container is highlighted as an effective method to allow water flow without disturbing the air pocket above.
  • Understanding of fluid dynamics and pressure systems
  • Familiarity with self-regulating valve mechanisms
  • Knowledge of backflow prevention devices
  • Basic principles of air and water interaction in sealed environments
  • Research the design and function of self-regulating valves in pressure systems
  • Explore the specifications and installation of backflow preventers
  • Study fluid dynamics principles related to air and water interaction
  • Investigate practical applications of pressure maintenance in sealed containers
Engineers, hobbyists, and anyone interested in fluid dynamics, pressure systems, and practical applications of air and water management in sealed environments.
speeddman
Let's say i have a sealed container with half water, half air, and i would like the air pressure to remain constant. how can i get a water hose to pour into this sealed air container without having the air escape up the hose?
Note* There is water leaving my container at the same rate it would be entering - so no need to worry about the water affecting the air pressure.
see attached image
also, let me know if there is a way to do so with an alternate outlet and inlet configuration
Thanks
Thanks
What you would need is a self-regulating way to pre-pressurize the water supply so that it matches the pressure inside the container.
This reminds me of the way that in the 1940's the frenchman Cousteau developed a diver's air supply unit, now known as scuba gear. (Until then divers on extended dives were dependent on air supply via a socalled 'umbilical'.)
In Cousteau's case a self-regulating valve system had to be devised that would reduce the pressure of the air inside the air cannisters to the pressure at the current diving depth. That is, at a depth with an ambient water pressure of 2 atmosphere the scuba gear had to offer air pressure at 2 atmosphere to the diver, and so forth.
The system that pre-pressurises the water supply for the cannister that you describe will have to do something similar.
Cleonis
If the water is coming from a valve, air will not escape up the hose*: there is nowhere for it to go.
*...in any quantity larger than the volume of the hose.
What do i mean by "...in any quantity larger than the volume"?
I'm not sure if i understand.
so no matter what the pressure of the incoming water is, the air won't be able to escape?
Am I missing something? If the entry and exit hose are in the bottom of the container, the water can flow in and out without disturbing the bubble of air at the top of the container.
If the water is coming from a valve, like a garden hose, the water in the garden hose can spill out into the container, depending on if the orientation of the hose allows it. You can try this at home - if you slope a garden hose, water will spill out of it after you turn it off at the faucet.
Air can't go backwards past the valve where you turn the water on.
Yes, that would be a simple solution to the problem.
Ok. thank you everyone. i guess i must have been over thinking this.
I am quite glad that i stumbled across pf.
speeddman
I just tested this system. unfortunately bubbles went up my hose. the water from the hose is sitting in a container open to air. i don't know what to do
Go have a drink.
ummm, first thing I thought of was the old camping coffee pot my grandfather made according to him during WW2.
It was a cylinder with one fitting that was about 1/4 of the way from the top or just below the water line. it came out and made a 90* turn up to just above the top. at the other side of the cylinder was another fitting like the first but it was about 1/4 of the way from the bottom, the pipe exited at 90* made it's way to the top and then arc'd over like a big tea spout.
here's the genius in it. fill it up leaving an air space in the can but a water line in the pipes. place on the fire and once it's near a boil remove to a cooler but still hot spot of coals and when ever you need hot water, pour cold water into the top pipe and an equal amount of hot water will pour out the other pipe. no need to constantly heat water in large batches.
Hot water heaters operate under the same principle.
Ohh and I got the pipe arrangement backwards, it's been 30yrs. the cold water feeds into the lower end.
here's a quick model in solidworks for you...
A backflow preventer is a commercial solution and they are designed to do just this. Basically, the idea is that by passing the water through an expansion valve, you create a pressure drop which will not allow fluid/air to pass back into the line. These are available for relatively cheap in a hardware store and are required on all outdoor hoses in commercial buildings to keep chemicals out of the public water supply. Also, a water trap (like is found under a kitchen sink) is designed to do the same thing. Water can pour into the sewer but gases from line cannot come back into the house. Much the same as the water heater described above.
www.cfdengineer.com
  • · Replies 16 ·
  • · Replies 27 ·
