How to make an animation in SymPy using Python
4 replies · 5K views · last reply
JD_PM
I want to make an animation where a (red) ball departs from (0,0) and draws the function ##f(x) = sin x##
This is what I know:
How to plot ##f(x) = sin x##
Screenshot of Python code plotting sin(x) from 0 to 2π with NumPy and Matplotlib, and the resulting blue sine curve on axes from 0 to about 6.3.
To do so I followed instructions from the worksheet. Actually I'd have done:
Screenshot of a Jupyter cell running SymPy code that plots sin(x) from -pi to pi, with the resulting Figure 1 showing a sine curve with f(x) on the vertical axis and x on the horizontal axis.
But I guess they want to me to it in that way because I have to do less work while coding for the red dot to draw the entire sine curve.
Now to plot just a piece of the function:
Python code plotting sin x with NumPy and Matplotlib, followed by the resulting graph: a blue sine curve from 0 to about 1.6 on the x-axis, with a red dot marking its point at index 50.
If we set i=50 and x runs from 0 to 200, we are aiming at plotting just 1/4 of ##f(x) = sin x## .
The line ax.plot(X, Y, 'o', color='red') locates the point at i=50 (I guess 'o' is just the command for the point).
But now, how can I code such an animation of ##f(x) = sin x## from (0,0)? I have read I should import:
import matplotlib.animation as animation
I've been looking for exercises on animations in SymPy in Python but found nothing.
Any help is appreciated.
I think that SymPy has nothing to do with animations. It is a functionality of matplotlib. You may want to check this link describing it. You can find there several examples, providing full code. It should be easy to pick one and rewrite it for your needs.
Thanks, in that link I found what I was looking for. There's a final issue now.
Screenshot of a Python matplotlib animation code cell above a Figure 1 window showing a blue dotted sine curve plotted from 0 to 2π, y-axis from -1 to 1.
How can I make the leading point red?
You should have second line element (matplotlib.lines.Line2D) for the red dot to be updated in your "update" function. In the third line of the code from your screenshot, you get only one line element, that is your blue line. So you should create an empty list of the line elements and using the "append()" method to add new line elements as many as you may need them to update.
Here is an example (including also a text field updated in the graph):
https://stackoverflow.com/questions/20624408/matplotlib-animating-multiple-lines-and-text?rq=1
