How to Maximize a Nonlinear Function with Limited Variables?
  • Context: Graduate
  • Thread starter Thread starter ericdavid
    Function Nonlinear
18 replies · 2K views
ericdavid
Hi to everyone,
I'm optimizing a nonlinear function but I'm struggling to achieve it. The function is the following:
X and i are relationed so i doesn't go to infinite. Do you have any idea how to maximize this function?
Thanks in advance,
Eric
on Phys.org
What do you mean by "related"? i is a summation index, not a free variable. The starting value is missing.
The sum has an explicit formula, this should be easy to simplify.
ericdavid said:
Hi to everyone,
What does this mean? Your summation appears to be from i = <something> to ##\infty##.
The summation in the formula for F(x) is unclear. Is this what you have in mind for the summation?
$$\sum_{i = 0}^{\infty}e^{-i(x + 2)}$$
Yes, it is from i to ∞, but if I want to optimize it I guess that I will have to set a bound.
And yes, the summation corresponds to what you have posted. Let's say that i is related to x as follows: i=T/x, T is a time. Therefore, x determines i.
This makes no sense -- "from i to ∞". i is merely the index. You have to give a starting value, such as 0 or 1 or whatever, and an ending value, such as 10 or N or ∞.
This also makes no sense. x is presumably a real number, and a summation index is usually an integer.
The summation that I wrote can be expanded like so:
##1 + e^{-(x + 2)} + e^{-2(x + 2)} + e^{-3(x + 2)} + \dots##
It's not at all clear to me or the other people replying in this thread what you're trying to do.
Apologies, I wanted to say that it goes from i=1 to inifinite. I will reformulate my question so you can understand it better.
I want to maximize this function:
And x is related to i as follows; i=T/x, where T is a constant. Due to the nature of the problem, i is an integer.
Thanks for your patience.
Eric
This still doesn't make sense. i is an index of the summation, and x occurs outside the summation (as well as being part of the things being summed).
i takes on an infinite number of values: 1, 2, 3, ... in the summation, but the x that multiplies the summation can't change with the change in index values.
Based on what you said, you can write the summation as ##\sum_{i = 1}^{\infty}e^{-i(T/i + 2)}##, but you can't replace either x outside the summation by T/i.
It seems that you're trying to come up with a formula for a function that involves a summation, without understanding how a summation works.
If we forget about the relationship between i and T, how would you optimize it?
Your question is related to find the max of this function "in general" or with constraints ?
I don't understand well how this function is defined, ##i## is the integer index in the sum but what about ##x##?, is real or integer? Has this function a domain?
If it is a real function try with the derivative...
Ssnow
ericdavid said:
If that is your function, it is identical to (just a different notation)
$$F(x)=\frac{1}{x+x \left( e^{-1(x+2)} + e^{-2(x+2)} + e^{-3(x+2)} + ... \right)}$$
You see how i disappears just by rewriting it? i cannot depend on anything.
You can use$$\sum_{i=1}^\infty e^{-i(x+2)} = \sum_{i=1}^\infty \left(e^{-(x+2)}\right)^i$$
The sum on the right (a sum over qi for some q) can be evaluated with a well-known formula.
Afterwards, you can use that a maximum of your function (which does not occur at 0) is a minimum of the inverse, 1/F(x). From there it should not be hard to look for minima.
Ssnow
Hi Ssnow,
x is a real, I'm working on a domain and i do not have any constrains more.
Thanks for your advice, so far the best I've received.
Can I use this formula?
By the way, how do you introduce formulas in this forum?
You can use this formula, to take the limit n->infinity you have to check if z is in the correct range for that.
You can use LaTeX for formulas. The quote in your post has two examples.
In this formula, the summaton begins at i=0, while in my case it's i=1. How can I solve that?
Thanks
In fact, my function is this one:
I posted a simplified one before, can I still express this one with a well-known formula?
Thanks
