How to measure fluorescence intensity time trace?
This discussion focuses on measuring fluorescence intensity time traces, emphasizing the importance of selecting appropriate excitation and emitted wavelengths. The excitation wavelength should ideally be chosen based on the fluorophore's absorbance spectrum, specifically at the wavelength with the highest absorbance, provided there is sufficient separation from the emission wavelength. The emitted wavelength is critical and should be selected based on the highest emission from the fluorophore, although alternative wavelengths may be used in specific applications like FRET to reduce crosstalk.
  • Understanding of fluorescence spectroscopy
  • Knowledge of fluorophore absorbance and emission spectra
  • Familiarity with FRET (Förster Resonance Energy Transfer) techniques
  • Experience with wavelength selection in optical measurements
  • Research methods for measuring fluorophore absorbance spectra
  • Learn about selecting emission wavelengths for optimal fluorescence detection
  • Explore FRET principles and applications in fluorescence measurements
  • Investigate tools for analyzing fluorescence intensity time traces
Researchers in biochemistry, molecular biology, and analytical chemistry who are involved in fluorescence measurements and analysis, particularly those working with fluorophores and FRET applications.
Yinxiao Li
I understand that fluorescence intensity time trace is constantly monitor the fluorescence intensity and plot it over time. But the question is at which excitation wavelength? Also, what is the emitted wavelength that is being measured? I suppose it should be two particular wavelengths, but how is the wavelength selected?
Chemistry news on Phys.org
The excitation wavelength does not matter so much as long as the fluorophore's extinction coefficient in that region is reasonable. You could take an absorbance spectrum of your fluorophore, and excite at the wavelength with the highest absorbance as long as there is reasonable separation between that wavelength and the wavelength at which you're monitoring emission.
Your answer is very helpful..But--Sorry I missed the part of emitted wavelength...I just changed the question. The extra question is what is the emitted wavelength being measured? The fluorescence intensity should be measured under one particular emitted wavelength, right?
Sorry that this is a simple question...
Usually you would measure the emission spectrum of the fluorophore you're using, then choose the wavelength that shows the highest emission. However, for certain applications (e.g. measuring FRET), you might choose a different wavelength to minimize crosstalk from other fluorophores in your sample.
15K
