How to measure ripple voltage on CRO
Ripple voltage can be measured on a CRO by switching the input to AC, which allows for the extraction of the AC component from the DC signal. Ripple refers to the fluctuations in voltage, while ripple voltage specifically denotes the amplitude of these fluctuations. Ripple factor is a percentage that compares the ripple voltage to the DC value. Understanding these distinctions is crucial for accurate measurements. The discussion concludes with a confirmation of clarity on the topic.
ritucrown
can we measure ripple factor using same?
again what is difference between ripple, ripple voltage and ripple factor?
Hi ritucrown.
To measure the ripple voltage, switch the input to AC and that extracts the AC component from the DC.
I'd venture that ripple factor is a percentage, relative to the DC value.
thank you, NascentOxygen
thamks for you help, now i got it...
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 52 ·
