How to measure the transfer function in Simulink?
To measure the transfer function in Simulink, utilize the "Linear Analysis Tool" from the Control System Toolbox, which allows for detailed analysis of system characteristics, including Bode plots. The "Bode Plot" block can also be employed to directly visualize the transfer function by processing input and output signals. Issues with the "PS Divide" block may arise, as it can lead to inaccuracies when dividing signals. Additionally, ensure that the simulation settings, such as the solver, are appropriate for your model to achieve accurate results. Properly configuring these tools will yield a more reliable representation of the system's frequency response.
jean28
Let's say I simulate a simple filter in simulink and I want to see the transfer function graph (bode plot) of it. What do I do to get Vout/ Vin? I tried using the "PS Divide" Block and divide the output voltage and the input voltage, but that didn't work. Could anyone help me out here?
This is what I tried:
http://i1226.photobucket.com/albums/ee410/jean28x/bode1.jpg
This is the graph I got:
http://i1226.photobucket.com/albums/ee410/jean28x/bode2.jpg
Thank you all very much.
The scale on your scope is way of. Hit the button next to the printer and uncheck the box saying something like "save only last 1000 data points". Simulate again and hit the button with the binoculars. Does the result seem to be correct now? Check with your analytical answer!
If no results appear, check the Matlab command window for warnings and errors. A divide block can cause problems for certain inputs.
Also this setup does not create the bode plot of the system. A bode plot is the frequency response, here you got only one frequency.
Further hints: A system can create a phase shift between the input and output. Comparing the input and output at the same instant of time gives no true information about the attenuation. How is this done in your model...
Ok thanks a lot! One more quick question. I am trying to simulate this circuit (quite complicated) and I can't seem to get an output signal that seems sinusoidal. I think it has something to do with the Refine factor, because when I simulate simpler circuits I DO get a good sine wave. Do you have any idea why this would act this way?
Circuit:
http://i1226.photobucket.com/albums/ee410/jean28x/finalproyect.jpg
Graph I get (instead of Sine Wave):
http://i1226.photobucket.com/albums/ee410/jean28x/simulinkpic3.jpg
Try changing solver. Now you are using ODE45, but other might be better for this system of equations.
http://www.mathworks.se/help/simulink/ug/choosing-a-solver.html
To measure the transfer function in Simulink, you can use the "Linear Analysis Tool" which is part of the Control System Toolbox. This tool allows you to analyze the linear characteristics of your system, including the transfer function. To use this tool, you need to first create a Simulink model of your system and then open the Linear Analysis Tool from the "Apps" tab in the Simulink window. From there, you can specify the inputs and outputs of your system and run the analysis. The tool will then display the transfer function, Bode plot, and other relevant information for your system. You can also use the "Bode Plot" block from the Simulink library to directly plot the transfer function of your system. This block takes in the input and output signals and automatically calculates the transfer function and plots the Bode plot. I would recommend using these tools instead of the "PS Divide" block, as they are specifically designed for this purpose and will provide more accurate results.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
35K
  • · Replies 18 ·
36K
9K
16K
  • · Replies 30 ·
