How to modify a power function?
  • Thread starter Thread starter SHRock
    Function Power
To modify a power function given two ordered pairs, substitute the points into the equation y = ax^b to create two equations. This results in two unknowns, a and b, which can be solved by dividing the equations to isolate b. Once b is determined, substitute it back into one of the original equations to find a. If multiple pairs yield slightly different values for a and b, averaging those values may be appropriate to account for experimental error. Utilizing nonlinear regression techniques can also assist in refining the estimates for a and b.
SHRock
Let's say I have 2 ordered pairs. I want to find the the a and b in the function. How would I do that?
y=ax^b
y/a=x^b
b=log(y/a)/logx
But now I have 2 variables. How would I find those variables?
y=ax^b
y/a=x^b
b=log(y/a)/logx
Substitute the points you have into your equation. Then you will have two equations in the two unknowns, a and b.
Yeah but the problem is I don't know how to reduce that.
Let's say I pick 2 points
(35,0.01)
(4.5,30)
so the functions will be
b=log(0.01/a)/log 35
b=log(30/a)log4.5
Let's go back to the original equation, y = axb
Using your points, we have
.01 = a * 35b
30 = a* 4.5b
Dividing the first equation by the second, we have
.01/30 = 35b/4.5b = (35/4.5)b
Can you solve that for b? Once you get b, then use either equation to find a.
.01 = a * 35b
30 = a* 4.5b
Oh ok thanks I get it. Now another little questions. Let's say if I do this for multiple ordered pairs. And a and b aren't always the same, but pretty close. Should get the average of those and plug it in as b? Because this is like a lab and error will occur.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
