How to Prove an Upper Bound for a Set of Real Numbers?
matematiker
Let A be a set of real numbers. If b is the supremum (least upper bound) of the set A then whenever c<b there exist an a in A such that a>c.
I considered two cases. The first one when the supremum b is attained by the set A. In this case there exists an a belonging to A such that a=b and the statement is proved.
In the second case the supremum is not attained by the set A, so for all a that belong to A, a<b. Here is where I get stucked. I cannot come up with an idea of an a larger than c but smaller than b.
Any hint in the right direction will be very much appreciated. Thank you !
How about a proof by contradiction? If for c≥a for all points a in A, what does that tell you about the least upper bound?
That would mean b is not the least upper bound since c is smaller than b and greater or equal to any a in A which is a contradiction since by hypothesis b is the supremum of A.
Awesome !
Thank you clamtrox !
Awesome !
Now I am trying to prove the statement in the other direction:
Let a,b,c be reals and let A be a set of real numbers. If c<b and there is an a in A such that a>c then b is the supremum of A.
From the givens I know that:
c<b
There is an a in A such that a>c.
What I need to prove is that for any a in A, a<=b.
I took a>c from the givens but that is where I get stucked because I do not know how to show that this a is greater or equal to b.
Do you have any hint?
Thank you in advance !
There's something wrong here... Let a=1, A={1}, c=0 and b=42. Then c<b and a>c exists, yet b is not the supremum. Maybe it should say "If for all c<b there exists a in A s.t. a>c ... "
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
