How to prove solution to Fick's second law by substitution
This discussion focuses on proving the validity of the solution to Fick's second law of diffusion, represented by the equation C(x,t) = (C1 + C2)/2 - (C1 - C2)/2 * erf(x/(2√(Dt))). The participants detail the differentiation process required to verify the solution, employing the error function (erf) and the fundamental theorem of calculus. The final solution confirms that the proposed solution satisfies Fick's second law through careful manipulation of derivatives with respect to both time and space.
  • Understanding of Fick's second law of diffusion
  • Knowledge of the error function (erf)
  • Proficiency in calculus, particularly differentiation
  • Familiarity with partial differential equations
  • Study the derivation and properties of the error function (erf)
  • Learn about the fundamental theorem of calculus and its applications
  • Explore advanced techniques in solving partial differential equations
  • Investigate numerical methods for approximating solutions to Fick's second law
Students and professionals in the fields of physics, chemistry, and engineering, particularly those focusing on diffusion processes and mathematical modeling of physical phenomena.
neromax
I am to prove that a solution to the differential equation Fick's second law is valid by substitution.
Fick's second law:
\frac{\partial C}{\partial t} = \frac{\partial}{\partial x} \left( D \frac{C}{\partial x} \right)
Solution to Fick's second law:
C(x,t) = \left( \frac{C_1 + C_2}{2} \right) - \left( \frac{C_1 - C_2}{2} \right) \text{erf} \left( \frac{x}{2 \sqrt{Dt}} \right)
The (Gauss) error function (erf) which I found online:
\text{erf}(z) = \frac{2}{\sqrt{\pi}} \int_o^z e^{-y^2} dy
I presume I am supposed to differentiate the proposed solution with respect to t once and compare it to the proposed solution differentiated twice with respect to x? But I am not sure how i shall handle the integral.
Can someone help me/point me to literature or give me some pointers on how to proceed?
If you have taken Calculus, then you should know "the fundamental theorem of Calculus"-
\frac{d}{dx} \int_a^x f(t) dt= f(x)
@HallsofIvy - Thanks for a reply. The problem bugging me though, is that i do not have x, but \frac{x}{2\sqrt{Dt}}, such that:
\frac{2}{\sqrt{\pi}} \frac{\partial}{\partial x} \int_0^{\frac{x}{2\sqrt{Dt}}} e^{-y^2}dy
Is this the correct change of limits and function of the integral?
<br /> <br /> \frac{\partial}{\partial x} C(x,t) = -B \frac{\partial}{\partial x}\int_0^{\frac{x}{2\sqrt{Dt}}} e^{-y^2}dy = -B \frac{\partial}{\partial x} \int_0^x e^{-y^2\left(4Dt \right)^{-1}}dy = -B e^{-x^2\left(4Dt \right)^{-1}}\\<br /> \frac{\partial^2}{\partial^2 x}C(x,t) = -B \frac{\partial}{\partial x} e^{-x^2\left(4Dt \right)^{-1}} = -B e^{-x^2\left(4Dt \right)^{-1}} \frac{\partial}{\partial x}\left( -x^2\left(4Dt \right)^{-1} \right) = B \frac{2}{Dt}\cdot x e^{-x^2\left(4Dt \right)^{-1}}<br />
Solved it!
I finally understood how it worked :wink:
<br /> <br /> D\frac{\partial}{\partial x} C(x,t) = -BD \frac{\partial}{\partial x}\int_0^{\frac{x}{2\sqrt{Dt}}} e^{-y^2}dy = -BD e^{-\left(\frac{x}{2\sqrt{Dt}}\right)^2} \frac{\partial}{\partial x} \left(\frac{x}{2\sqrt{Dt}}\right) = -BD e^{-\frac{x^2}{4Dt}} \left(\frac{1}{2\sqrt{Dt}}\right) \\= \frac{-BD}{2\sqrt{Dt}} e^{-\frac{x^2}{4Dt}} \\<br /> \frac{\partial}{\partial x} \left( D \frac{C(x,t)}{\partial x} \right) = \frac{\partial}{\partial x} \frac{-BD}{2\sqrt{Dt}} e^{-\frac{x^2}{4Dt}} = \frac{-BD}{2\sqrt{Dt}} e^{-\frac{x^2}{4Dt}} \frac{\partial}{\partial x} \left( - \frac{x^2}{4Dt} \right) \\= \frac{BDx}{4}\left( Dt \right)^{-\frac{3}{2}}e^{-\frac{x^2}{4Dt}}\\<br /> <br /> \frac{\partial}{\partial t} = -B \frac{\partial}{\partial t}\int_0^{\frac{x}{2\sqrt{Dt}}} e^{-y^2}dy = -B e^{-\left(\frac{x}{2\sqrt{Dt}}\right)^2} \frac{\partial}{\partial t} \left(\frac{x}{2\sqrt{Dt}}\right) = -B e^{-\left(\frac{x}{2\sqrt{Dt}}\right)^2} \left( - \frac{Dx}{4(Dt)^{3/2}} \right) \\= \frac{BDx}{4}\left( Dt \right)^{-\frac{3}{2}}e^{-\frac{x^2}{4Dt}} \qquad \square<br /> <br />
  • · Replies 105 ·
