How to replace 0603 capacitors on a PCB
  • Thread starter Thread starter Ephant
24 replies · 4K views
Ephant
Hi,
What techniques would it be possible to replace 0603 capacitors which has size only of 0.063 in x 0.031 in (smaller than a mosquito?) (see attached image with the C indicating the 0603 caps)
If this is extremely difficult, what services out there that can replace 3 or 4 0603 capacitors in single PCB only? If none, can anyone replace mine?
Also can one just replace 0603 capacitor with normal size capacitor with the same say 10 microFarah (and others)?
What kind of soldering iron(s) do you have? Do you have a hot air soldering station?
Do you have a desk magnifier (lens)?
I have a desk magnifier and ordinary small tip hot iron soldering unit only. But as soon as I used, it, the plastics in the PCB just melted.
Can you borrow a 2nd iron? What kind of iron do you have? I'm guessing it's not a Metcal...
BTW, how do you know that this capacitor is bad? Did it fail open or short, or just change value?
If it failed open, I'd leave it there. You still have the problem of attaching the replacement, but not the problem of getting the old one out.
Similarly, if something else, I'd consider destroying it with a tiny pair of diagonal cutters or similar rather than get it out. Desoldering is trickier than soldering.
Dyking it off can delaminate the SMT pads, which can complicate adding back in a replacement.
See my soldering set attached. I already used smaller tweezer to remove the old 0605 in the right most capacitor. I just wanted to change the values to alter the cut off frequencies. Can I just use an ordinary normal size capacitor and just solder the wire legs of them to the PCB?
In my personal experience 1206 are reasonably easy to solder/replace (you just need magnifier and some testing to find the best temperature of the iron). I admit I never tried with the smaller ones but I know people who did and from what I remember they used exactly the same kind of soldering station and solder tip I have.
However, I am using a soldering station similar to the one on the picture - as far as I am aware it is a cheap clone of some successful design, can't remember details. $40 or less.
Um, did you want to increase the capacitance?
That iron does not appear to be compatible with soldering small SMT components. You need a temprature-controlled soldering iron like the one @Borek posted or a Metcal unit.
Yup. But I'd take "might" over "will burn it up".
Obviously, SMT is not designed for anythng like what the OP wants to do. So it's an issue of what the "least worst" option is.
Without the right equipment it's next to impossible. A SMT hot air rework station is fairly cheap but good magnification and soldering tools are priceless.
Or the lovely flat blade tips METCAL has for doing inline packages (SMTC-106, I think).
1700441803836.pngI use those to remove 0603 and 0805 components, particularly when not worried about the component's welfare. They clean the pads nicely also
I want to lower the capacitance. Why can't I use a big ceramic capacitor like in the attached picture? I can just easily solder the two legs in the pcb.
For rework purposes for testing, sure. For production purposes, obviously no.
What's the application? Is it just a test board that you can muck around with. Can you achieve your goals with added capacitance? I'm really bad, but I've done on it test boards... it's a lot easier to just stack some caps on there to add capacitance if that's an option you can consider. I'm no way suggesting it's pretty or would meet any standards gosh I've had people arguing with me about things like flight qualifications I'm just trying to debug this broken board to figure out what's wrong and we can propose proper changes after... so if it's like just testing or proof of concept then why not :)
Below is not my picture I just Googled it to show you what I mean. Picture below is pretty extreme but it definitely gets the point across.
If your application is really sensitive or you need to watch for certain resonances you can assume a slightly larger ESL series inductance for your modeling.
  • Haha
hutchphd said:
Or the lovely flat blade tips METCAL has for doing inline packages (SMTC-106, I think). View attachment 335800View attachment 335800I use those to remove 0603 and 0805 components, particularly when not worried about the component's welfare. They clean the pads nicely also
METCAL is an addiction. Once you pay the admission price it's never ending series of fixes. Most of the prototype boards use METCAL for soldering.
To the OP, good magnification and steady hands are a requirement of good results. If the iron is on the pad for more than 3 seconds, expect problems.
Reworking SMT boards takes some skill only acquired through practice. Also, as others have said, good tools (which your soldering iron isn't). I would try to find some scrap SMT PCBAs to practice on.
I want to decrease the the capacitance from 10 nanoFarad to 20 picoFarad. If the capacitance is decreased, what happens to the resonances if I put 20 picoFarad ceramic capacitor with wire legs that can easily solder to it?
Oh, my suggestion wont work if you're trying to decrease the capacitance :( I think the earlier suggestions sound better you might want to consider those instead.
I recommend you share the application or maybe some of the schematic, or both. It might help with suggestions.
Please look at this schematic of the Olimex-EKG-EMG. I actually saw a web site how to modify it to increase the high frequency cut off from 40 Hz to 500 Hz (see below too). In my case. I want to increase the cut off to at least 1000 Hz.
https://www.olimex.com/Products/Duino/Shields/SHIELD-EKG-EMG/open-source-hardware
schematic of the product
https://www.olimex.com/Products/Dui.../resources/SHIELD-EKG-EMG-REV-B-SCHEMATIC.pdf
How to modify the Olimex from 40 Hz to 500 Hz.
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC9143621/
I saw the following product from UFI (Biopotential 2122) with high frequency cut off of at least 1000 Hz (and higher but I need only 1000 Hz for now). But they are selling it to me for $1200.
https://www.ufiservingscience.com/datasheets/2122manual.pdf
If the capacitors in the Olimex is modified to 1000 Hz. Can it matches UFI Bioamplifier 2122 performance? Kindly study the Olimex schematics and comment if the components have the the best design also possibly matching even very high end unit or it is not up to it.
For this UFI 2122 description "Introduction The Model 2122 is a differential amplifier for use with low level signals -- 2 microvolts and above -- ranging from DC to 10 KHz. Primarily designed as biological instrumentation, the Model 2122 is well suited to many other demanding applications. It features high common mode rejection, high input impedance, low noise, small size, and excellent frequency response. The Model 2122i includes subject isolation, but is otherwise identical to the standard Model 2122."
".... Less than 2 μV peak to-peak, DC to 100 Hz with 10K Ohm source".
Can the Olimex also has 2 μV peak to-peak, DC to 100 Hz with 10K Ohm source noise? Is this a common specification of typical amplifier these days and can easily be achieved? What happens if the frequency is increased to 1000 Hz, what usually is the peak to peak noise in microvolt? (Have you encountered or heard)?
Some disclaimers:
I'm not newbie in bioamplifiers (I owned 5 EEG units and my simulators in my biology research lab), so please don't keep emphasizing plugging it to AC can electrocute me and stop this thread right away. I'd never plug it to AC. I used isolator. And in the Olimex, it's connected with laptop with battery only. Never the AC plugged in. To all users too. Always use isolator to prevent turning it into electric chair or just don't do any project like this unless you know what you are doing.
2nd. Don't convince me that there is nothing to see in the EMG at 1000 Hz. I'm not building an EMG which has limit only of 500 Hz. I'm getting a Biopotential amplifier with cut off of 1000 Hz to prove to myself the body plexuses or nerve centers can't emit high frequency that can be measured in surface mount biopotential sensors. Yes. This may sound ridiculous but as biologist, I need to prove it so kindly dont tell me not to get the circuit and just believe. Also No. I'd never use needle. It's all surface measurement of the biopotential so worry not about sticking needles and hurting the body. I 100% will not use needles.
3rd. Can you recommend other biopotential amplifier that has very good quality at 1000 Hz and can detect even very small EMG-like level (1 microVolt and so) signal at low noise and high common mode rejection with same or better quality that the UFI Biopotential 2122 ? I just need 1 channel. It's alternative to the UFI Biopotential 2122 which is selling me at $1200. Problem with it is they only accept credit cards and wire transfer. So since I don't want to share my credit card. I have to wire transfer but it is more hassled. If I can find something with same quality at it and pay online, then it is much more convenient.
Thank you so much guys!
Using biomedical equipment according to the manufacturer's guidelines is one thing, trying to modify or design your own biomedical instrumentation is another. I have done both, and the latter is a very involved process (including getting safety approvals per published standards).
I'm not comfortable with giving such advice here at PF, so this thread is now closed. Thanks all for your good rework advice and suggestions -- that part of the thread was fine.
