How to solve a differential equation using substitution?
9 replies · 3K views · last reply
find_the_fun
Solve the DE using an appropriate substitution.
$$(x-y)dx+xdy=0$$
First step is to determine the substitution. I was told for homogeneous ODEs to always make the substitution y=ux but the substitution u=x-y looks better.
Let u = x-y then u'=-y' which means y'=-u'
rewrite the original equation x-y+xy'-o
now plugging in u and u' gives u+x(-u')=0 which gives x du = -u dx and integrating gives xu=-ux which doesn't make any sense.
I would first rewrite the ODE as:
$$\d{y}{x}=\frac{y}{x}-1$$
Using the substitution $$v=\frac{y}{x}$$, we then get:
$$\d{v}{x}=-\frac{1}{x}$$
Can you proceed?
Can you proceed?
I don't really know what the overall procedure is when it comes to substitution. Wikibooks states the procedure is
  1. Take a term of the equation and replace it with a variable v. The key is that the new variable must cover all instances of the variable y. Otherwise substitution would not help.
  2. Solve for
    in terms of
    and
    . To do this, take the equation
    where
    is the term you replaced and take its derivative.
  3. Plug in
    and solve for
  4. Plug
    into the original term replaced, and solve for
I'm unclear on the first step. How do you know what the substitution should be? What made you say let [math]v=\frac{y}{x}[/math]? EDIT: in step 1 they say "take a term", what's a term?
  2. Solve for in terms of and . To do this, take the equation where is the term you replaced and take its derivative.
  3. Plug in and solve for .
  4. Plug into the original term replaced, and solve for .
A term is simply a part of the function.
It comes from experience knowing to substitute v = y/x. In general, if it CAN be written like a function of y/x, when the substitution should be valid and give you a separable DE in terms of v and x.
Ok I think I'm starting to understand. One attempt I made led me to the wrong answer, where did I go wrong?
$$(x-y)dx + xdy=0$$
let $$y =ux$$ then $$dy=x du + u dx$$
Plugging in $$(x-ux)dx+x^2du+xu dx = 0 $$
simplifies to [math]x^2du+xdx=0[/math]
so one solution is $$x=0$$ (or should it be y?)
Now we can factor out an x so $$x(x du + dx)=0 \implies xdu+dx=0
Now can we just integrate so [math]\int x du + \int dx = xu+x+C=0[/math] putting back in $$u=\frac{y}{x}$$ gives $$x \frac{y}{x} +x+C \implies y=-x+C$$ but the answer key has [math]y+xln|x|=xC[/math]
Your substitution is correct, but at the end you do some invalid steps.
We need to solve $xdu+dx=0$. Separable of the variables yields
$$-xdu = dx \Leftrightarrow -du = \frac{dx}{x} \Leftrightarrow -u = \ln|x|+C$$
Back-substitution gives
$$\frac{-y}{x}=\ln|x|+C$$
and hence the solution is $-y = x \ln|x|+Cx \Rightarrow y + x \ln|x|=Cx$.
Can you point out which steps are invalid so I don't repay them again.
topsquark said:
Hint:
Take a closer look at [math]\int xu~du[/math]. Is x a constant with respect to u?
-Dan
No, x is a variable used by u. So what does that matter? And where did I use [math]\int xu~du[/math]?
As Topsquark already said, Take a closer look at your post:
You claim: $\int x du = x u$, which means that you've treated $x$ as a constant. But the integral is with respect to $u$ and $u$ is a function of $x$.
