How to solve a limit in two variables with an indeterminate form at (0,0)?
  • Thread starter Thread starter Kenneth1997
    Limit Variables
The limit of the function lim (x,y)->(0,0) (ln(1+2x^2+y^2))/(x^2+3y^2)^2 approaches +∞, indicating that the limit does not exist. The discussion emphasizes the importance of testing multiple paths to determine the behavior of limits in two variables. Converting to polar coordinates (x = r cos θ, y = r sin θ) is recommended to analyze the limit as r approaches 0. The use of l'Hospital's rule is also suggested for further evaluation of the limit.
  • Understanding of limits in multivariable calculus
  • Familiarity with polar coordinates and their application in limits
  • Knowledge of l'Hospital's rule for evaluating indeterminate forms
  • Basic properties of logarithmic functions
  • Study the application of polar coordinates in evaluating limits in multivariable calculus
  • Learn about l'Hospital's rule and its conditions for use in indeterminate forms
  • Explore examples of limits that approach infinity and how to prove their non-existence
  • Investigate the behavior of logarithmic functions near zero and their implications in limits
Students and educators in calculus, particularly those focusing on multivariable limits, as well as mathematicians interested in advanced limit evaluation techniques.
Kenneth1997
i've been tought that i have to find another equation always bigger than this one that goes to 0 at (0,0) to find a solution. or if the solution doesn't exist, try to find two paths with two different results in 0,0. whichever path i chose, this goes to +infinite. in class i have never seen a limit in two variables that exists and goes to +inf, having an indetermination form, so i don't have a clue on how to solve it. any ideas?
[/B]
If you choose a path and it gives + infinity, then the limit can't exist (if it would exist, it would give the limit value along every path).
Kenneth1997 said:
1. lim (x,y)->(0,0) (ln(1+2x^2+y^2))/(x^2+3y^2)^2
3. I've been tought that i have to find another equation always bigger than this one that goes to 0 at (0,0) to find a solution. or if the solution doesn't exist, try to find two paths with two different results in 0,0. whichever path i chose, this goes to +infinite. in class i have never seen a limit in two variables that exists and goes to +inf, having an indetermination form, so i don't have a clue on how to solve it. any ideas?
Please stop using bold font; it is distracting and it looks like you are yelling at us.
Anyway, your thoughts as given in your first two sentences are not correct. There are lots of other ways that may be used besides the two you mention. Sometimes a method that works in one problem fails in another problem, so you need to try something else.
If I were trying this problem I would switch to polar coordinates ##x = r \cos \theta,\: y = r \sin \theta,## with ## r > 0## and ##0 \leq \theta < 2 \pi## (in radians). Then, you want the limit as ##r \to 0+##. If the limit exists for any ##\theta,## and does not depend on the value of ##\theta,## then you have a genuine 2D limit. If the limit fails to exist for at least some values of ##\theta,## then your 2D limit does not exist. If the limit exists for all ##\theta## but is different for different values of ##\theta,## then again your 2D limit does not exist. This problem calls out for the use of l'Hospital's rule.
Finally: this message belongs in "Calculus and Beyond" rather than "Introductory Physics".
i think what you are saying is incorrect, the polar form doesn't include non linear paths, so you can't be sure if the limits exist.
yea but, what if every path you find gives you +inf?
Does it matter? infinity is not a real number thus cannot be a limit by definition.
He never claims that this method proves that the limit exists. He rather claims that this method can be used to show that the limit does NOT exist, and he is completely right when saying this.
in R* the limit exist and I am considering that domain.
whatever, it doesn't work anyways, it goes to infinite for any angle
The polar form does include nonlinear paths -- what's happening is that r is approaching zero, but ##\theta## isn't specified. A point (x, y) could be approaching the pole along a spiral or other path along some curve.
Remember to be polite to people who are trying to help you... Or even people in general...
So, if you claim that the limit is ##+\infty##, there is work to do. You have to prove:
##\forall M \in \mathbb{R} : \exists \delta > 0: \forall (x,y) \in \mathbb{R}^2: 0 < \Vert (x,y) \Vert < \delta \implies \frac{\ln(1+2x^2 + y^2)}{(x^2 + 3y^2)^2} > M##
Or you can settle with the easier answer that the limit doesn't exist in ##\mathbb{R}## (probably the answer your instructor intended).
What do you mean by R*? I'm not familiar with that notation. And how do you know the limit exists?
Which means the limit doesn't exist. So again, why do you think the limit exists?
vela said:
What do you mean by R*? I'm not familiar with that notation. And how do you know the limit exists?Which means the limit doesn't exist. So again, why do you think the limit exists?
I think he means the limit may be infinite.
Mark44 said:
The polar form does include nonlinear paths -- what's happening is that r is approaching zero, but θ\theta isn't specified. A point (x, y) could be approaching the pole along a spiral or other path along some curve.
it doesnt, that's why ((x^2)*y)/(x^4+y^2)) result in 0 in (0,0) with polar form for every angle but actually doesn't exist, i think its because of the way the distance is arranged.
yep.
didnt mean to appear rude, sorry for that.
Math_QED said:
∀M∈R:∃δ>0:∀(x,y)∈R2:0<∥(x,y)∥<δ⟹ln(1+2x2+y2)(x2+3y2)2>M
is it possible to find a function that is always smaller that i know goes to infinite in 0,0?
The polar representation sometimes allows you to say for sure that either that a limit exists, or that it does not.
Certainly, the polar form suffices in this case to draw a conclusion about the existence-or-not of a limit, and if you had actually tried it for yourself you would have seen this.
yep.
If you look at the graph of the ##\ln## function you will see that ##0 < \ln (1 + 2x^2 + y^2) < 2x^2+y^2 < 2(x^2+y^2) ##. Also: ##(x^2 + 3 y^2)^2 > (x^2+y^2)^2,## so the rest is pretty easy.
you know what i do? do you have a camera in my room?i've spent hours on this limit. what you are saying is just incorrect. if id write in my exam "sometimes the polar form sufficies to draw conclusions" i would get a 0. it can suggest you what is the result, it can make you certain, but you would not prove it mathematically.
Ray Vickson said:
If you look at the graph of the ln\ln function you will see that 0<ln(1+2x2+y2)<2x2+y2<2(x2+y2)0 < \ln (1 + 2x^2 + y^2) < 2x^2+y^2 < 2(x^2+y^2) . Also: (x2+3y2)2>(x2+y2)2,(x^2 + 3 y^2)^2 > (x^2+y^2)^2, so the rest is pretty easy.
you are basically saying that the limit is smaller then +infinite, that doesn't give you information about the exact value.
Right: sorry about that. Just forget post #15.
Well, when I do it I get a definite conclusion, with no waffling about it working sometimes or not. In this case it actually does work, but I cannot write here the required steps to show that (not allowed under PF rules).
cant i just say the function is > then f(x,y)=(ln(1+x)/(x^4)) that goes to +inf and so my function goes to +inf aswell?
Converting to polar form for this function doesn't help, because the polar form results in different values for different values of the angle. Converting to polar form is helpful in cases where ##\theta## is no longer present.
The polar form is very useful in this example, because the function becomes
$$f = \frac{\ln(1+r^2+r^2 \cos^2 \theta)}{r^4 (9 - 12 \cos^2 \theta + 4 \cos^4 \theta)},$$
which is of the form
$$\frac{\ln(1 + a r^2)}{b r^4} $$ for some "constants" ##a,b## that depend on ##\theta,## but are positive for all ##\theta \in [0,2 \pi].## So, the question is whether or not something of the form ##\ln(1+a r^2)/r^4## has a limit as ##r \to 0.## One way to answer that is to bound the logarithm in some reasonable way; another way is to use l'Hospital's rule.
The one I was referring to was ##f(x, y) = \frac{x^2y}{x^4 + y^2}##
Yes, I agree. That is a good example of how the polar method sometimes fails, but works often enough that it is still worth trying on an unexplored example.
yep.
Yes, but I had the inequalities going the wrong way before.
For small ##h > 0## we have
$$\ln (1+h) > h^2 - \frac 1 2 h^2$$
Apply this to the numerator ##\ln(1 + 2x^2+y^2) > \ln(1 + x^2+y^2) = \ln(1+r^2),## where ##r^2 = x^2+y^2.##
In the denominator we have ##(x^2 + 3 y^2)^2 < (3 x^2 + 3 y^2)^2 = 9 r^4,##
so the function satisfies
$$f = \frac{\ln(1+2x^2 + y^2)}{(x^2 + 3 y^2)^2} > \frac{r^2 - \frac 1 2 r^4}{9 r^4}= \frac 1 9 \left(\frac{1}{r^2} - \frac{1}{2} \right)$$
thanks man, this should do the trick
still think it doesn't include linear paths, or the theta would be a variable not a constant, and in that case you couldn't treat it anymore as a one variable limit and you have the same problem as before. btw, theta still appears in the function i was trying to find the limit.
sparo1 said:
i've been tought that I need to discover another condition constantly greater than this one that goes to 0 at (0,0) to discover an answer. or on the other hand if the arrangement doesn't exist, attempt to discover two ways with two distinct outcomes in 0,0. whichever way I picked, this goes to +infinite. in class I have never observed a limit in two factors that exists and goes to +inf, having a vagary frame, so I don't have an idea on the best way to understand it. any thoughts?
hope you didnt register to this forum just for this
If ##\theta## is no longer present, it can have any value, so isn't constant. You're still thinking that r has to approach 0 along some straight line with ##\theta## constant, and that isn't so.
I don't understand your claim: the polar method (with fixed ##\theta\:##) does, in fact, include linear paths. That is, when ##\theta## is fixed, the paths ##r \to 0## are straight lines pointing to ##(0,0)##. If a limit fails to exist for at least one value of ##\theta## the 2D-limit fails to exist, and you are done. If the limit exists for each ##\theta## but is different for some different values of ##\theta## then, again, the 2D-limit fails to exist and you are done.
The only problematical case is when the "polar" limit exists and is the same for all values of ##\theta##, because that means that all straight-line limits exist and are independent of the line you choose. However, we know from examples that a 2D-limit can still fail to exist in this case, because going to zero along a curved path may give you different answers. Those types of questions are inherently tricky, and there seems to be no well-known standard methods available for treating them; it is as though each question stands on its own, and it is hard to generalize from one example to another.
everything you are saying is correct, every single word. but now you are going against mark44, because he says that the polar form includes also paths that are not straight lines.
  • · Replies 26 ·
