How to Solve Commutators Using the Jacobian?
69 replies · 8K views · last reply
You need to use \hbar, not /hbar.
I'm going to use hats over the operators so you can keep track of what's going on. The first thing on the right is ##\hat{p}_x \psi = -i\hbar \frac{\partial \psi}{\partial x}##, so
$$\hat{p}_x \hat{x} \hat{p}_x \psi = \hat{p}_x \hat{x} (-i\hbar)\frac{\partial \psi}{\partial x} = -i\hbar\,\hat{p}_x \hat{x} \frac{\partial \psi}{\partial x}.$$
Now, again, evaluate the what the rightmost operator does.
if it is supposed to be [tex]\frac{∂ψ}{∂x}[/tex], then I don't know what to do with this. If it is [tex]-i\hbar \frac{∂}{∂x} x[/tex], then it is just [tex]-i\hbar[/tex]
What is the operator farthest on the right in
$$-i\hbar\,\hat{p}_x \hat{x} \frac{\partial \psi}{\partial x}?$$
I meant a hatted operator. ##\psi'(x)## is just a function.
Then it is [itex]\hat{x}[/itex], but I don't know its formula, or if it even has one besides [itex]\hat{x}[/itex]
In the coordinate basis, which is the basis you're working in, the operator ##\hat{x}## when acting on a function ##f(x)## simply multiplies that function by ##x##. That is to say, ##\hat{x}f(x) = xf(x)##.
So in this case it does nothing that would influence its right side, except for multiplication, right? Then I only see multiplication of two operators, [itex]\hat{p}x[/itex], which is just [itex]-i\hbar[/itex], and [itex]x\hat{p}\psi[/itex]. What can I do with this?
No. Say A and B are matrices and x is a vector. What you keep doing is equivalent to saying ABx = (Ax)(Bx). That's not how it works.
Just work right to left and remember that ##\hat{p}## acts on everything to its right.
the only thing I see is [itex]-i\hbar\frac{∂x}{∂x}\frac{∂ψ}{∂x}[/itex]. Where am I making mistake?
[itex]-i\hbar\frac{∂x\frac{∂\psi}{∂x}}{∂x}[/itex]?
Gosh, I finally understood my mistake:P I just treated the whole thing as simple standard multiplication, just like I should do in normal mathematical case, however in case of operators I should just multiply every operator by the variable on its right side:D In normal situation it seems illogical, looking like this: ##(A+B)CD=(AD+BD)CD##, but in case of operators it should look like this ##(-i\hbar\frac{\partial }{\partial x}x+i\hbar\frac{\partial}{\partial x})(-i\hbar\frac{\partial }{\partial x})\psi=(-i\hbar(x\frac{\partial \psi}{\partial x}+\psi\frac{\partial x}{\partial x})+i\hbar\frac{\partial \psi}{\partial x})(-i\hbar\frac{\partial \psi}{\partial x})=(-i\hbar x\frac{\partial \psi}{\partial x}-i\hbar\psi i\hbar x\frac{\partial \psi}{\partial x})(-i\hbar\frac{\partial \psi}{\partial x})=(-i\hbar\psi)(-i\hbar\frac{\partial \psi}{\partial x})=-\hbar^2\psi \frac{\partial \psi}{\partial x}=-\hbar^2\frac{\partial }{\partial x}##
Unfortunately, I still do not know how to solve it using Jacobi identity... I am not even sure if I interpret it correctly. I tried to use the commutator ##[p^2_x,x]=[p_x p_x,x]##, use the given fact ##[p_x,x]=-i\hbar##, or ##[x,p_x]=i\hbar## and substitute it to Jacobi identity formula ##[p_x,[p_x,x]]+[p_x,[x,p_x]]+[x[p_x,p_x]]=0##, but those commutators zero themselves even before I sum them up. How to do this?
Rorshach said:
Gosh, I finally understood my mistake:P I just treated the whole thing as simple standard multiplication, just like I should do in normal mathematical case, however in case of operators I should just multiply every operator by the variable on its right side:D In normal situation it seems illogical, looking like this: ##(A+B)CD=(AD+BD)CD##, but in case of operators it should look like this ##(-i\hbar\frac{\partial }{\partial x}x+i\hbar\frac{\partial}{\partial x})(-i\hbar\frac{\partial }{\partial x})\psi=(-i\hbar(x\frac{\partial \psi}{\partial x}+\psi\frac{\partial x}{\partial x})+i\hbar\frac{\partial \psi}{\partial x})(-i\hbar\frac{\partial \psi}{\partial x})##
Unfortunately, you haven't understood your mistake. You're still doing the same thing you did before. It doesn't work at all like (A+B)CD = (AD + BD)CD.
After you apply the rightmost ##\hat{p}##, you have ##\hat{p}\hat{x}\,\left(-i\hbar \frac{\partial\psi}{\partial x}\right)##. Now ##-i\hbar\frac{\partial\psi}{\partial x}## is just another function. Let's call it ##f##. So now you have ##\hat{p}\hat{x}f##. What is ##\hat{x}f## equal to? Call that result ##g##. Then apply ##\hat{p}## to ##g##. What do you get?
Ignoring the constants, yes, that's what you get. So what's the derivative of g equal to?
No. What is ##g## equal to?
Oh right, I confused just derivative with applying the operator:P
it came down to ##-i\hbar(\frac{\partial g}{\partial x})=-i\hbar (-i\hbar\frac{\partial \psi}{\partial x})##, which is basically a half of the result, so it is correct, right?
Rorshach said:
##-i\hbar x\frac{\partial x}{\partial x}##
That's not correct. Where's you get ##\frac{\partial x}{\partial x}## from?
I just made a mistake while writing the result in code, it should be ##-i\hbar x\frac{\partial \psi}{\partial x}##
OK, so what do you get when you differentiate that?
I differentiated it by x, but from my experience I again made a mistake somewhere...
What if you wrote ##g=xf##? What do you get when you differentiate g?
oh shoot... it is ##x\frac{\partial f}{\partial x}+f##... but it only complicates the matter, now I have ##-i\hbar(x\frac{\partial f}{\partial x}-i\hbar\frac{\partial \psi}{\partial x})##
