How to Solve for Amplitude and Phase Constant in an Oscillation Problem?
  • Thread starter Thread starter irvine752
    Oscillation
The problem involves an air-track glider attached to a spring oscillating with a specified period. The original poster seeks to determine the phase constant and amplitude based on given displacement and velocity values at a specific time.
  • Participants discuss the original poster's attempt to solve for the phase constant and amplitude using trigonometric relationships. Questions arise regarding the absence of a time variable in the equations and whether the calculations are valid at times other than t=0.
Some participants suggest that the original poster may have overlooked an additive constant and question the validity of assuming t=0 for the calculations. There is an ongoing exploration of how to correctly incorporate time into the equations and whether the approach to solving for two variables is appropriate.
Participants note that the problem involves specific values for displacement and velocity at a time other than zero, which may affect the calculations for amplitude and phase constant.
irvine752
I'm not quite sure on what I did wrong. Can anyone please help me with this?
An air-track glider attached to a spring oscillates with a period of 1.50sec . At the glider is 4.60cm left of the equilibrium position and moving to the right at 33.4cm/s.
What is the phase constant , if the equation of the oscillator is taken to be ? Give an answer in the range -pi < Q < pi.
phase constant = Q
Amplitude = A
angular frequency = w
x(t) = Acos(wt+Q)
v(t) = -Awsin(wt + Q)
w = (2pi)/period
4.6 = Acos(Q)
33.4 = -Awsint(Q)
Q = atan(.334/(.046*(2pi/1.5))
It appears that this is close to the right answer, but I'm missing some "additive constant". I probably posted this in the wrong section just by judging by the number of responses on this. If someone would kindly help me, I'd really appreciate it. :frown:
I think you might have missed a constant in your calculation there, but is there a way that you can figure out, t, at these instant where you're given x and v.
The term w*t seems to have disappeared, from the argument of both trig functions, not sure you can do this, or at least can't call it Q unless you're at t=0 or some integral number of cycles after that. In otherwords, you neet to solve for A and Q both if I'm not mistaken. You can get A from the approacch you were using once you know the angle. See it that leads anywhere
The term w*t is no longer present b/c it was a function of time, and at the instance when t =0 or time = 0sec, w * t or (2pi/period) *t became 0. I then solved for A (Amplitude) from the first equation then substituted that into the second eqaution. If I'm not mistaken, isn't that the way to solve for two variables using two equations?
The displacement is 4.6 cm and the velocity 33.4 cm/s at some time t different from 0. As denverdoc mentioned, you can write those equations but with a value different then Q and solve for A.
Once you know A, you can solve for Q.
16K
