How to solve recurrence relation ?
  • Context: Undergrad
  • Thread starter Thread starter jjosephh
    Recurrence Relation
The discussion revolves around solving recurrence relations, specifically focusing on two examples: the first being a second-order homogeneous relation and the second involving a non-homogeneous relation. Participants explore methods for finding general solutions, particular solutions, and the implications of having repeated roots.
  • One participant presents the recurrence relation a_n + 2a_{n-1} + 2a_{n-2} = 0 and attempts to solve it using characteristic equations, leading to r^2 + 2r + 2 = 0.
  • Another participant suggests using the quadratic formula to find complex roots and indicates that the general solution will involve linear combinations of these roots.
  • Participants discuss the need to find constants K1 and K2 using initial conditions a_0 = 1 and a_1 = 3.
  • A new recurrence relation a_{n+2} - 6a_{n+1} + 9a_n = 3*2^n + 7*3^n is introduced, with participants noting that the homogeneous solution yields repeated roots of 3.
  • One participant mentions that for repeated roots, the solution must include polynomial terms multiplied by the exponential terms.
  • There are discussions about finding particular solutions, with varying approaches suggested, including using forms like f(n) = B1*2^n + B2*3^n.
  • Participants express confusion over the calculations for constants in particular solutions and the implications of the roots found in the characteristic equations.
Participants generally agree on the methods for solving recurrence relations but express differing opinions on the specifics of finding particular solutions and handling repeated roots. The discussion remains unresolved regarding the best approach to these aspects.
Some participants note the complexity of the Z-transform method introduced, while others suggest sticking to more straightforward methods. There are also mentions of potential confusion regarding the calculations for constants in particular solutions.
This discussion may be useful for students and practitioners interested in recurrence relations, particularly those looking for various methods to approach solving them and understanding the implications of different types of roots.
jjosephh
The Example is ;
Solve the recurrence relation a n + 2a n-1 + 2a n-2 = 0 where n ≥ 2 and a 0 = 1 a 1 = 3
a n = nth order
a n-1 = (n-1)th order.
a n-2 = (n-2)th order.
I've started the solving ;
a n = r^n
so
the equation will be ;
r^n + 2r^(n-1) + 2r^(n-2)
r^2 + 2r + 2 = 0
I could'nt do anything after find the roots ?
What should i do ?
Thanks for helping.
Welcome to PF!
Hi jjosephh! Welcome to PF! :smile:
(try using the X2 and X2 tags just above the Reply box :wink:)
If your characteristic equation, r2 + 2r + 2 = 0, has roots p and q,
then the general soultion will be linear combinations of solutions to the equations
an = pan-1 and an = qan-1 :smile:
The problem is ;
Solve the recurrence relation a n + 2a(n-1) + 2a(n-2) = 0 where n ≥ 2 and a0 = 1 a 1 = 3
I said;
a n = rn
and found this equation ;
r2 + 2r +2 = 0
I have to find r1 and r2 to write ;
K1r12 + K2r22 = a n
I know a0 and a 1 so i can find K1 and K2
But i have problem with roots :)
Use the quadratic formula. You'll have two complex roots (conjugates, naturally).
I found
r1 = -1 -i
r2 = -1 +i
an = K1 r1n + K2 r2n
I'm trying to find K1 and K2
a0 = 1 => K1 + K2 = 1
a1 = 3 => K1(-1-i) + K2(-1+i) = 3
Can you help me to find K1 and K2
Hi jjosephh! :wink:
From the first equation, K2 = 1 - K1, so put that in the second equation, and that gives you an equation for K1. :smile:
Thank you for all helps
I have another question ;
an+2 - 6an+1 + 9an = 3*2n + 7*3n
where n>=0 and a0 = 1 a1 = 4
I think there are two path to solve this problem.
First path is find homogenous solution and the second is particular solution
So ;
In homog. solution i found r1 and r2 are both equal to 3.If roots are equal what should i do ? Or the roots are correct ?
Thanks for all advices .
The two independent solutions are an = 3n and an = n3n :smile:
When you have multiple roots, you must multiply the term with a polynomial. For double roots, the polynomial is n+1, and for triple roots, it's [tex]\frac{\left(n+1\right)\left(n+2\right)}2[/tex], etc.
We extend the definition of a to the negative domain, and let [tex]a_n=0[/tex] for [tex]n<0[/tex]. Then we find the value of [tex]a_{n+2}-6a_{n+1}+9a_n[/tex] for [tex]n<0[/tex].
[tex]a_1-6a_0+9a_{-1}=-2[/tex]
[tex]a_0-6a_{-1}+9a_{-2}=1[/tex]
[tex]a_{n+2}-6a_{n+1}+9a_n=0[/tex] for [tex]n<-2[/tex].
Then the equation becomes:
[tex]a_{n+2}-6a_{n+1}+9a_n=H\left[n\right]\left(3\cdot 2^n+7\cdot 3^n\right)-2\delta\left[n+2\right]+\delta\left[n+1\right][/tex], where H is the unit step function.
The Z-transform of this equation is:
[tex]A\left(z\right)=\frac{\frac 3{1-2z^{-1}}+\frac 7{1-3z^{-1}}-2z^2+z}{\left(z^2-6z+9\right)}=\frac{\frac 3{1-2z^{-1}}+\frac 7{1-3z^{-1}}-2z^2+z}{\left(z-3\right)^2}=\frac{3\left(1-3z^{-1}\right)+7\left(1-2z^{-1}\right)+\left(z-2z^2\right)\left(1-5z^{-1}+6z^{-2}\right)}{\left(1-2z^{-1}\right)\left(1-3z^{-1}\right)\left(z-3\right)^2}=[/tex]
[tex]\frac{z^2-6z+1+17z^{-1}}{\left(1-2z^{-1}\right)\left(1-3z^{-1}\right)\left(z-3\right)^2}=[/tex]
[tex]\frac{z^4-6z^3+z^2+17z}{\left(z-2\right)\left(z-3\right)^3}[/tex]
We can write this as:
[tex]A\left(z\right)=\frac P{z-2}+\frac {Qz^2+Rz+S}{\left(z-3\right)^3}[/tex]
Then:
[tex]P\left(z-3\right)^3+\left(Qz^2+Rz+S\right)\left(z-2\right)=P\left(z^3-9z^2+27z-27\right)+Q\left(z^3-2z^2\right)+R\left(z^2-2z\right)+S\left(z-2\right)=z^4-6z^3+z^2+17z[/tex]
We can try solving it in this way:
[tex]P+Q=0[/tex]
[tex]-9P-2Q+R=0[/tex]
[tex]27P-2R+S=0[/tex]
[tex]-27P-2S=z^4-6z^3+z^2+17z[/tex]
This has the following solution:
[tex]P=-z^4+6z^3-z^2-17z[/tex]
[tex]Q=z^4-6z^3+z^2+17z[/tex]
[tex]R=-7z^4+42z^3-7z^2-119z[/tex]
[tex]S=13z^4-78z^3+13z^2-221z[/tex]
The inverse Z-transform of [tex]\frac{-z^4+6z^3-z^2-17z}{z-2}+\frac {13z^6-85z^5+56z^4+208z^3-118z^2+17z}{\left(z-3\right)^3}[/tex] is:
[tex]2^n\left(-8H\left[n+3\right]+24H\left[n+2\right]-2H\left[n+1\right]-17H\left[n\right]\right)+[/tex]
[tex]\frac{3^n}2\left(351H\left[n+3\right]\left(n+4\right)\left(n+5\right)-765H\left[n+2\right]\left(n+3\right)\left(n+4\right)+168H\left[n+1\right]\left(n+2\right)\left(n+3\right)+[/tex]
[tex]208H\left[n\right]\left(n+1\right)\left(n+2\right)-\frac{118}3H\left[n-1\right]\left n\left(n+1\right)+\frac{17}9H\left[n-2\right]\left(n-1\right)n\right)[/tex]
So, that's your function, if my calculations are correct. If not, just follow this general method and you should get the correct answer. It can be simplified further by ignoring the H's and adding all the terms containing n.
(just got up :zzz: …)
Gigasoft said:
The Z-transform of this equation is …
Z-transform ??
jjosephh, ignore this very complicated method and just do it the way you were going to! :smile:
Yeah, I don't know if there's a simpler way to solve this, but remember that when you take into account the right hand side, the equation has four roots, three of which are 3 and one that is 2. So, the solution must have the form:
[tex]a_n=A2^n+(B+Cn+Dn^2)3^n[/tex]
Hello again,
what about the particular solution ?
should be f(n) = B12n + B23n
jjosephh said:
Hello again,
Hello again jjosephh! :smile:
I assume that you've got B1 but you've found the same method doesn't work for B2 ? :redface:
Start by trying the same trick that you're using for the ("= 0") general solution. :wink:
you mean ;
f(n) = B1(2n + 3n)
jjosephh said:
…what about the particular solution ?
jjosephh said:
you mean ;
f(n) = B1(2n + 3n)
No … go back to B12n + B23n
what did you get for B1 ?
B1 = 3
B2 = -7/9
and the solution is ;
(I got before hom. solution A1= -11/9 A2 = 4/3)
an = -11/9*2n + 4/3*3n +3*2n -7/93n
by the way a(0) = 1and a(1)=4
n>=2
I'm confused … how did you get that homogeneous solution from an+2 - 6an+1 + 9an ? :confused:
(and I get your B1, but not your B2)
r1,r2 = 3
so the solution must be
an+2 = rn
an+2 = A1*r1n + A2*n*r2n
an+2 = A1*31n + A2*n*32n
I think i need help :)
he he :biggrin:
No, if two roots of the characteristic equation are the same, you use Arn + Bnrn (three roots the same, + Cn2rn and so on …)
in this case, (A + Bn)3n :smile:
(and that should help you with the particular solution :wink:)
I could'nt calculate the particular solution
I said
F(n) = B1*2n + B2*3n
and after the equation
B1 = 3
But there is no B2..
what should be f(n) ?
could you help me please ..
if
f(n) = A*2^n + (B+Cn+Dn^2)*3^n
A = 3
18D + 9Cn = 7
so what can i do ... ??
jjosephh said:
if
A = 3
18D + 9Cn = 7
Hi jjosephh! :smile:
I get just 18D = 7
(but 18D + 9Cn = 7 would mean that 9C = 0, since it has to be true for any n :wink:)
  • · Replies 36 ·
