How to Solve the Differential Equation \(\frac{dx}{dt} = \frac{x+t}{x-t}\)?
The discussion revolves around solving the differential equation \(\frac{dx}{dt} = \frac{x+t}{x-t}\). Participants are exploring methods to find general solutions and discussing the nature of the equation.
  • The original poster attempts a substitution \(u=x+t\) to transform the equation but questions the separability of the resulting expression. Some participants suggest that the equation is indeed separable and encourage separating and integrating. Another participant shares a successful substitution method and raises questions about the choice of substitution in differential equations.
There is a mix of attempts to clarify the separability of the equation and to provide alternative substitution methods. One participant claims to have solved the problem and offers their approach for reference, while others are still exploring the implications of different substitutions.
Participants note confusion regarding the original equation and its complexity, as well as the challenges of selecting appropriate substitutions for differential equations.
retracell
Find the general solutions to \frac {dx}{dt} = \frac {x+t}{x-t}
Edit: Sorry I messed up the original equation.
No idea.
I tried to use substitution u=x+t to change it into a separable equation but I only got to:
\frac {du}{dt} = \frac {2u-2t}{u-2t}
which I don't think is separable.
Actually, the original differential equation is separable. Try separating and integrating accordingly. After all, your right hand side is a function only of x.
Sorry I messed up the original equation. The one I need help on isn't as simple. :/
Actually I just solved this question after much head scratching. I'm going to post it here for reference if needed because I know a lot of Google searches point to Physics Forums.
Letting u=\frac{x}{t} then \frac{dx}{dt}=t\frac{du}{dt}+u
Substituting into original DE you'll get t\frac{du}{dt} = \frac{-u^2+2u+1}{u-1}
This then becomes separable and simply solve for \int\frac{u-1}{-u^2+2u+1}du=\int\frac{1}{t}dt and make sure to back-substitute.
I'm pretty sure this is right but I'm not 100%. I still do not understand how do we choose the substitution equation for DE or is it similar to choosing substitution for integration?
It is right.
Your original equation can be written in the form x'=\frac{1+x/t}{1-x/t}
When the DE is the form of y'=F(y/x) substitute y/x =u.
Then y=ux, y'=u'+u, so u'+u=F(u), u'=F(u)-u, a separable equation.
See this place: http://www.math.hmc.edu/calculus/tutorials/odes/odes.pdf
ehild
  • · Replies 105 ·
11K
