How to Solve the Fourier Integral in Eq. (27) Involving Position Vectors?
The discussion revolves around solving a Fourier integral involving two-dimensional position vectors and a two-dimensional vector in the Fourier domain, as presented in Eq. (27) of a referenced article. Participants are exploring methods to derive the result claimed by the author, focusing on the complexities introduced by certain parameters and the structure of the integral.
  • One participant expresses frustration in solving the integral and seeks guidance on achieving the result from Eq. (27).
  • Another participant notes that the presence of the factor ##Sign(i,j)## complicates the treatment of parameters ##\sigma_i##, ##\sigma_j##, and ##\delta_{ij}##, suggesting that more information is needed about these terms.
  • A participant clarifies the meanings of the parameters, indicating that ##\sigma_i## and ##\sigma_j## relate to spectral density spread, while ##\delta_{ij}## pertains to correlation width.
  • One participant proposes that the parameters can be treated as constants, but the final result will depend on whether indices are equal or not.
  • Another participant describes a method for rewriting the integral and suggests a change of variables to simplify the expression, although they acknowledge that the algebra remains complex.
  • A different approach is introduced using matrix notation, proposing a block-matrix representation of the integral and discussing eigen-decomposition to facilitate the calculation.
Participants do not reach a consensus on the best method to solve the integral, with multiple approaches being discussed and no clear agreement on which is preferable or correct.
The discussion includes unresolved mathematical steps and dependencies on the definitions of specific parameters, which may affect the approaches taken by participants.
David932
Where , rho 1 and rho 2 are two dimensional position vectors and K is a two dimensional vector in the Fourier domain. I encountered the above Eq. (27) in an article and the author claimed that after integration the right hand side gives the following result:
I tried to solve this integral but couldn't get it right. please can anyone here can guide me how to get this result from Eq. (27).
This integral has been annoying me for a few weeks!
Thank you so much
If it weren't for that factor ##Sign(i,j)## in the result I would have thought that we could treat ##\sigma_i##, ##\sigma_j## and ##\delta_{ij}## as arbitrary constants in (27) and that you were simply trying to find the Fourier transform of a multivariate Gaussian (which I would do by diagonalizing the quadratic form to get a bunch of 1-D Fourier transforms of Gaussians, which can be performed many ways). But it seems like something else is going on here.
So I think we need more information. What do ##\sigma_i##, ##\sigma_j## and ##\delta_{ij}## stand for, and what is ##Sign(i,j)##?
Jason
Jason
Hi thanks for the reply. The parameters ##\sigma_i## and ##\sigma_j## corresponds to the spread of spectral density and ##\delta_{ij}## is the width of the correlation between the i and j components of a field. and sign (i, j) = 1 when i = j and sign (i,j) = -1 if i is not equal to j.
Okay. I think I get it now. We can treat the parameters as constants, but the final simplifications can take into account that the answer will depend on whether ##i=j## or ##i\neq j##.
What part are you getting stuck on? Can you do the integrals and are just struggling with the algebra to simplify the expression, or are you having trouble doing the integrals? I've derived a simple expression for the general integral, but have not done the messy algebra to see if the final result agrees with the posted answer.
jason
Hi Jason,
First, thank you so much for the reply.
I am struggling with the doing the integrals. I tried and tried but couldn't get the result.
Okay. By the way, my "simple" formula I thought I had was wrong. The correct way is messy algebra, but conceptually quite simple.
The basic form of your integral is:
I = \int_{-\infty}^{\infty} d^2\mathbf{r}_1 \int_{-\infty}^{\infty} d^2\mathbf{r}_2\, e^{-i2\pi\mathbf{k \cdot }(\mathbf{r}_1-\mathbf{r}_2)} \, e^{-\mathbf{r}_1 \cdot \mathbf{r}_1 /a_1^2}\,e^{-\mathbf{r}_2 \cdot \mathbf{r}_2 /a_2^2}\, e^{-2 b \mathbf{r}_2 \cdot \mathbf{r}_1 }
We can re-write this,
I = \int_{-\infty}^{\infty} d^2\mathbf{r}_1\, e^{-i2\pi\mathbf{k \cdot } \mathbf{r}_1}\, e^{-\mathbf{r}_1 \cdot \mathbf{r}_1 /a_1^2} \, J(\mathbf{r}_1)
where,
\begin{eqnarray}
J(\mathbf{r}_1) & = & \int_{-\infty}^{\infty} d^2\mathbf{r}_2\, e^{i2\pi\mathbf{k \cdot} \mathbf{r}_2} \,e^{-\mathbf{r}_2 \cdot \mathbf{r}_2 /a_2^2}\, e^{-2 b \mathbf{r}_2 \cdot \mathbf{r}_1 }
\end{eqnarray}
Now change variables using ##\mathbf{y} = \mathbf{r}_2/a_2## to get
\begin{eqnarray}
J(\mathbf{r}_1) & = & a_2^2 \int_{-\infty}^{\infty} d^2\mathbf{y} \,e^{i2\pi a_2 \mathbf{k \cdot} \mathbf{y}} \,e^{-\mathbf{y} \cdot \mathbf{y}}\, e^{-2 b a_2 \mathbf{r}_1 \cdot \mathbf{y} } \\
& = & a_2^2\int_{-\infty}^{\infty} d^2\mathbf{y} \,e^f
\end{eqnarray}
Where all the mess is in ##f##. Re-writing,
\begin{eqnarray}
f & = & i2\pi a_2 \mathbf{k \cdot} \mathbf{y} -\mathbf{y} \cdot \mathbf{y} -2 b a_2 \mathbf{r}_1 \cdot \mathbf{y} \\
& \equiv & \mathbf{s \cdot} \mathbf{y} -\mathbf{y} \cdot \mathbf{y} .
\end{eqnarray}
where the above defines ##\mathbf{s}=i2\pi a_2 \mathbf{k} -2 b a_2 \mathbf{r}_1##. Now we want to find a new integration variable ## \mathbf{z} = \mathbf{y} - \mathbf{w}## for a constant ##\mathbf{w}## that makes the linear term above go away. We look at ##f##,
\begin{eqnarray}
f & = & \mathbf{s \cdot} \mathbf{y} -\mathbf{y} \cdot \mathbf{y} \\
& = & \mathbf{s \cdot} \mathbf{z} + \mathbf{s \cdot} \mathbf{w} - \mathbf{z} \cdot \mathbf{z} - \mathbf{w} \cdot \mathbf{w} - 2 \mathbf{w} \cdot \mathbf{z}
\end{eqnarray}
so if ##\mathbf{w} = \mathbf{s}/2## we get,
\begin{eqnarray}
f & = & \mathbf{s \cdot} \mathbf{s} /2- \mathbf{z} \cdot \mathbf{z} - \mathbf{s} \cdot \mathbf{s}/4 \\
& = & \mathbf{s \cdot} \mathbf{s} /4- \mathbf{z} \cdot \mathbf{z}
\end{eqnarray}
and we have,
\begin{eqnarray}
J(\mathbf{r}_1) & = & a_2^2 e^{ \mathbf{s \cdot} \mathbf{s} /4} \int_{-\infty}^{\infty} d^2\mathbf{z} \,e^{-\mathbf{z} \cdot \mathbf{z}} \\
& = & \pi \, a_2^2 e^{ \mathbf{s \cdot} \mathbf{s} /4}
\end{eqnarray}
Now, ##\mathbf{s \cdot} \mathbf{s} /4 = \zeta_1 \mathbf{k \cdot} \mathbf{k} + \zeta_2 \mathbf{r}_1 \cdot \mathbf{r}_1 + i \zeta_3 \mathbf{k \cdot} \mathbf{r}_1 ##; doing the algebra will give the the values of the real ##\zeta_1##,##\zeta_2##, and ##\zeta_3##.
So our original integral becomes,
I = \pi \, a_2^2 e^{\zeta_1 \mathbf{k \cdot} \mathbf{k}} \int_{-\infty}^{\infty} d^2\mathbf{r}_1 \, e^{-i(2\pi-\zeta_3)\mathbf{k \cdot } \mathbf{r}_1}\, e^{-\mathbf{r}_1 \cdot \mathbf{r}_1 (\zeta_2 + 1/a_1^2)}
This can be integrated using the same trick above. The algebra will be really messy, but this is do-able. Hope this helps!
Jason
I have another way that yields a simple result that may be easier to deal with. I will use matrix notation, so dot products will be ##\mathbf{k \cdot x} = \mathbf{k}^T\mathbf{x}## where the T superscript represents transpose.
Let ##\mathbf{r}## be a 4 x 1 vector that contains ##\rho_1## and ##\rho_2## stacked on top of each other, and ##\mathbf{k}## be the 2x1 vector wave-vector. Then the integral is of the form
\begin{eqnarray}
I & = & \int_{-\infty}^{\infty} d^4 \mathbf{r} \, e^{i 2 \pi \mathbf{k}^T B \mathbf{r}}\, e^{-\mathbf{r}^T A \mathbf{r}}
\end{eqnarray}
Where ##B## is a 2x4 matrix and ##A## is a positive definite symmetric 4x4 matrix. For your problem I believe these have a very special form. If ##I_2## is a 2x2 identity matrix, then in block-matrix notation I think your problem can be represented
\begin{eqnarray}
B & = & \left( \begin{array} & I_2 & -I_2 \end{array} \right) \\
A & = & \left( \begin{array} & a I_2 & b I_2 \\ b I_2 & c I_2 \end{array} \right) \\
\end{eqnarray}
The results below do not rely on these forms, but they are probably helpful in doing the algebra to get the final answer in a form you want.
Anyway, now we use the fact that ##A## is positive definite to do an eigen-decomposition, ##A = P \Lambda P^T##, where ##\Lambda## is the diagonal matrix of eigenvalues and ##P## is an orthogonal matrix of eigenvectors. Then the integral can be written,
\begin{eqnarray}
I & = & \int_{-\infty}^{\infty} d^4 \mathbf{r} \, e^{i 2 \pi \mathbf{k}^T B \mathbf{r}}\, e^{-\mathbf{r}^T P \Lambda P^T \mathbf{r}}
\end{eqnarray}
Now we do a change of variable to ##\mathbf{y} = \Lambda^{1/2} P^T \mathbf{r}##. Note that the Jacobian is ##\left| \Lambda^{1/2} P^T\right|=\left| \Lambda\right|^{1/2} =\left| A \right|^{1/2}##, where ##| \cdot |## represents the determinant. So we have
\begin{eqnarray}
I & = & \left| A \right|^{-1/2}\int_{-\infty}^{\infty} d^4 \mathbf{y} \, e^{i 2 \pi \mathbf{k}^T B P \Lambda^{-1/2} \mathbf{y}}\, e^{-\mathbf{y}^T \mathbf{y}} \\
& = & \left| A \right|^{-1/2}\int_{-\infty}^{\infty} d^4 \mathbf{y} \, e^{\mathbf{s}^T\mathbf{y} - \mathbf{y}^T \mathbf{y}}
\end{eqnarray}
where ##\mathbf{s} = i 2 \pi \Lambda^{-1/2} P^T B^T \mathbf{k}##. Now we do the same trick as before to get rid the of the term linear in ##\mathbf{y}## (by letting ##\mathbf{z}=\mathbf{y}-\mathbf{s}/2##) and end up with,
\begin{eqnarray}
I & = & \left| A \right|^{-1/2}e^{\mathbf{s}^T\mathbf{s}/4} \int_{-\infty}^{\infty} d^4 \mathbf{z} \, e^{ - \mathbf{z}^T \mathbf{z}} \\
& = & \pi^2 \left| A \right|^{-1/2}e^{\mathbf{s}^T\mathbf{s}/4}
\end{eqnarray},
Now, ##\mathbf{s}^T\mathbf{s} = -4 \pi^2 \mathbf{k}^T B P \Lambda^{-1/2}\Lambda^{-1/2} P^T B^T \mathbf{k}=-4 \pi^2 \mathbf{k}^T B A^{-1} B^T \mathbf{k}##. So we finally have
\begin{eqnarray}
I = \pi^2 \left| A \right|^{-1/2}e^{-\pi^2 \mathbf{k}^T B A^{-1} B^T \mathbf{k}}.
\end{eqnarray}
The fact that ##A## and ##B## have such special forms will hopefully make this expression reducible. For example forumulas in
https://en.wikipedia.org/wiki/Block_matrix
can be used to find the inverse of ##A## quite easily, and I suspect the determinant of ##A## is also not so bad.
Good luck,
Jason
I found a nice formula for the determinant. Start from the equation between (1) and (2) of,
https://en.wikipedia.org/wiki/Woodbury_matrix_identity
\begin{eqnarray}
\left(\begin{array} & A & U \\ V & C \end{array} \right) & = & \left(\begin{array} & I & UC^{-1} \\ 0 & I \end{array} \right) \left(\begin{array} & A-UC^{-1}V & 0 \\ 0 & C \end{array} \right) \left(\begin{array} & I & 0 \\ C^{-1}V & I \end{array} \right)
\end{eqnarray}
Taking the determinant yields
\begin{eqnarray}
\left| \left(\begin{array} & A & U \\ V & C \end{array} \right) \right| & = & \left|A-UC^{-1}V \right| \left| C \right|
\end{eqnarray}
In your case all of the blocks are proportional to ##I_2##, so this should be easy to compute.
jason
Dear Jason,
Thank you so much for the great help and giving priceless time to guide me in solution of this integral. I am trying to solve it with the approaches you mentioned. I hope I can find a reasonable solution to this integral. I also tried to solve the integral with using the formula, integral (exp(-bx^2) exp(iax))dx = sqrt(pi/b)exp(-a^2/4b) but I couldn't get the required result.
Did you try the approach I gave in post 7? When i plug in the parameters of your problem into equation 20 I get a result that is almost the one you posted. Instead of ##sign(i,j)## I get ##\pi^2##.
In retrospect I do not understand how the sign factor could possibly appear. For the special case ##\kappa=0## you have an inyegral of a Gaussian, which must be positive. Likewise, it seems inevitable that there should be a ##\pi^2##. So i do not see how your posted solution would be correct.
Hi Jason,
I tried your approaches but I find it a bit difficult to understand fully. Maybe I don't have enough skills and a more 'mechanical' or brute force approach may be easier for me to understand. Now I will try once again the approaches you mentioned if I can get answer with it.
Thank you so much for the huge help.
Regards
  • · Replies 16 ·
  • · Replies 50 ·
