How to solve this 2nd order nonlinear differential equation
22 replies · 39K views · last reply
tornado681
Hello all,
This is the first time I've stumbled across this site, but it appears to be extremely helpful. I am a meteorology grad student, and in my research, I have run across the following 2nd order non linear differential equation. It is of the form:
y'' + a*y*y' + b*y=0
where a and b are constants
Can this equation be solved analytically? If not, what program does one recommend for solving it numerically? There is also a slightly more complex form of this equation:
y'' + a*y*y' + b*y=c
where a, b and c are constants
If anyone could assist me in solving this or direct me to a source for solving it numerically, it would be most appreciated.
Thanks,
--tornado
Try the substitution y' = u to reduce it to a first order system of two ODEs. (Source:Tenenbaum/Pollard)
Ie., your first ODE becomes the system y' = u, uu' = -ayu - by, where in the second eq. u is treated as u(y) and u' = du/dy, which we can then plug into the first equation to integrate for y(x). The second equation is separable, so there is a straightforward analytic solution.
slider,
Im not following you. Could you go into a let more detail if possible. Thanks,
--tornado
Assuming y is function of x, y' = u. u' = d^2y/dx^2 = d/dy (dy/dx) dy/dx by the chain rule. This is equivalent to u du/dy. Hence u' = u du/dy.
After substituting for y' = u, the ODE is u' = -ayu - by. Replacing u' with u du/dy gives:
u du/dy = -y(au+b) This equation is separable and hence solvable. Once you have u(y), you have dy/dx = u(y), which is again separable and solvable.
defennder,
I understand how you get: u' = -ayu - by when you set y'=u
I don't understand how u'=u du/dy . I appreciate you trying to work me through this. Any additional explanation would be appreciated.
Specifcally, how is this so:
--tornado
That follows from the chain rule.
[tex]\frac{d^2y}{dx^2} = \frac{d}{dx} \left ( \frac{dy}{dx} \right ) = \frac{d}{dy} \left ( \frac{dy}{dx} \right ) \ \frac{dy}{dx}[/tex]
Replace [tex]\frac{dy}{dx}[/tex] with u.
When I solve u' = -ayu - by I get:
[tex]\frac{u}{a}-\frac{b}{a^2}ln[|{au+b}|]+C_1 =-\frac{1}{2}y^2 + C_2[/tex]
So then we need to make the above equation u=u(y) correct? Since we have a ln (natural log), is this possible? Any more help is most appreciated. Thanks,
--tornado
--tornado
I don't get that. From du/dy= -y(au+ b) we can get du/(au+b)= -ydy so, integrating both sides, (1/a)ln(au+ b)= -(1/2)y2+ C. I don't know what you mean by "make u= u(y) correct". Solve for u? Without your additional "u/a" that's easy:
[tex]au+ b= C'e^{-\frac{y^2}{2}}[/tex]
where C'= aeC.
where C'= aeC.
Actually u' isn't du/dy.
[tex]u' = \frac{du}{dx} = \frac{du}{dy} (\frac{dy}{dx}) = u \frac{du}{dy}[/tex]
That's where the u/a term comes, once you do long division of u/(au+b).
Defennder,
How do you rewrite u in terms of y only? Can it be done?
Honestly I have no idea if it's possible. It never occurred to me earlier because I didn't actually attempted the DE itself, I just noted it would be solvable if such could be done.
tornado681 said:
Defennder,
Yes, that is a simple application of the chain rule. In fact, that application to differential equations is a standard method called "quadrature"
Actually he was referring to this post:
--tornado
I really don't see how to write u in terms of y there. And anyway the post which resurrected this thread and which preceded yours appears to have been deleted.
Does anyone can help me to solve this second order non linear ODE:
y'' + (2/x)(y') - (1/2y)(y')(y') = K,
y' = dy/dx
y'' = dy'/dx
y = y(x)
I've already guess y=Ax^2 satisty this equation, but I want to solve it analitically..
Please help!
Thank before..
Hi,
I'm trying to solve y''(t) + w02 y(t) = k y(t)2 sin(w t). Does anybody know, how to get a particular solution?
Thanks.
Miriam100 said:
Hi,
Thanks.
There's probably no general analytic expression. At least, wolfram alpha doesn't give one, even when I give it initial conditions.
How large is k supposed to be compared to [itex]\omega_0^2[/itex]? If it's supposed to be small, you could do perturbation theory to get an approximation solution valid when [itex]ky(t) \ll \omega_0^2[/itex].
try (f(x+0) - f(x))/0
divide out the zero
and say tadah, solved numerically. whatever the hell that means.
Thanks for your help. The instructions say 'solve the problem analitically', so I guess I counstructed a wrong equation. It's without y^2, so there's no problem anymore. Tnx.
To recap:
[tex] u \equiv y'[/tex]
Then, the second derivative became:
[tex] y'' = \frac{d y'}{d x} = \frac{d u}{d y} \frac{d y}{d x} = u \frac{d u}{d y}[/tex]
and your equation becomes:
[tex] u u' + a y u + b y = c[/tex]
where [itex]u' \equiv du/dy[/itex]. I think some previous posters made a mistake in converting the second derivative.
Thanks for advice. However, it turned out that I constructed a wrong differential equation at the beginning. A new one was very simple to solve.
