How to Use Vector Analysis Identity to Solve a Closed Loop Integral?
4 replies · 4K views
neelakash
we are to show a=(1/2) closed loop integral over [r x dl]
I suppose this can be done formally from the alternative form of Stokes' theorem that can be obtained by replacing the vector field in curl theorem by VxC where C is a constant vector
The identity is :
surface int [(da x grad) x V]=closed loop integral over [dl x V]
The RHS matches.But how to show that LHS leads to the required value?
There is an identity:
[tex]\oint{\bf dr\times V}={\bf \int(\nabla V )\cdot dS<br /> - \int dS(\nabla\cdot V)}[/tex].
This can be derived by dotting the left hand side by a constatn vector, and then applying Stokes' theorem.
Applying this with V=r works.
OK,thank you.Your method worked nicely...
First I was sceptical about the grad V in your RHS...However,I started from the very beginning by dotting c with the required integral and it worked well.
There is an easier way I overlooked. Just take
[tex]{\vec k}\cdot\oint{\vec r}\times{\vec dr}[/tex]
where k is a constant vector, and apply Stokes' theorem.
I did just that...your dr reolaced by dl...
