How was this equation differentiated?
  • Thread starter Thread starter amaya244
6 replies · 2K views
amaya244
Hi guys, this is my first post, a friend of mine said I should try the site out. Here it goes.I have a function: Max (c1) = u(c1) + 1/1+p * u(c2)
(c2) is equal to this: (1+r)^2 * A0 + (1+r) (Y1-c1) + Y2
Substituting it into the max gives: u(c1) + 1/1+p * u [(1+r)^2 * A0 + (1+r) (Y1-c1) + Y2]FOC, I got: u'(c1) = 1+r/1+p * u'(c2)
However, I think I'm wrong. Can someone please check this for me?
(please show working)
Amy xx
I have an function: Max (c1) = u(c2) + 1/1+p * u(c2)
(c2) is equal to this: (1+r)^2 * A0 + (1+r) (Y1-C1) + Y2
I have no idea what you're asking. In the equation above, you have Max (c1) = u(c2) + 1/1+p * u(c2).
The way you wrote this suggests that Max is a function of variable named c1, but the other side of the equation involves c2, not c1.
Another point of confusion is trying to determine what you mean by u(c2) + 1/1+p * u(c2). Is u a number or a function? Also, what you wrote does not mean what you think it means. Apparently there is a fraction somewhere, but without parentheses, I can't tell what's in the numerator and what's in the denominator.
For example if you write (a + b)/(c + d) without parentheses, it would be a + b/c + d. Should this mean a + [b/(c + d)], [(a + b)/c] + d, or just plain a + [b/c] + d?
u(c2) + 1/1+p * u [(1+r)^2 * A0 + (1+r) (Y1-C1) + Y2]
What does FOC mean?
Amy xx
Sorry Mark44, I totally understand what you mean. Let me explain a little.
Firstly, I made an error. c1 should indeed be in place of c2 (in the 1st utility function).
Secondly, 1/1+P is a 'discount factor' that can be simply written as a 'B':
u(c1) + B u(c2)
When B is close to 1, the individual is impatient and chooses to consume quite a lot of his future income.
Thirdly, let me explain the variables:
u(.) is an instantaneous utility function
ct is period t consumption
Yt is income at period t
At is wealth at period t
The problem is thus dynamic! The individual maximises consumption subject to a budget constraint.
u(c1) + B u(c2) s.t. c2 = (1+r)^2A0 + (1+r)(Y1-c1) + Y2
This is usually called Milton Friedman's Permanent Income Hypothesis. FOC is short for the 'first order condition'.
This first order condition is known as a Euler equation.
u'(c1) = (1+r) + B u'(c2)
I just want to know how c1 is maximised/differentiated.
That would be 1/(1 + P).
amaya244 said:
u(c1) + B u(c2)
I think this is what you're trying to say:
Maximize u(c1) + B*u(c2), where c2 =A0(1 + r)2 + (1 + r)(Y1 - c1) + Y2.
If you substitute for c2 in the expression you want to maximize, you'll get a function that has one variable: c1.
Let's call this function F.
F(c1) = u(c1) + B*u(A0(1 + r)2 + (1 + r)(Y1 - c1) + Y2)).
The first part is easy enough to differentiate. For the second part you need to use the chain rule.
No, just 1/1 + P actually :-)
Thank you Mark44,
Can I just ask, once you differentiated the first and second parts of F, with respect to c1, did you arrive at the following equation?
u'(c1) = (1 + r) β*u'(c2)
Amy xx
Yeah, right...
amaya244 said:
Thank you Mark44,
Well, I didn't do the differentiation.
The equation you show here is the result of setting F'(c1) = 0, and then solving for u'(c1).
Mark44 said:
Yeah, right...
Pffft!
That's what I thought, but then where did C2 come from? Didn't it get substituted out?
