How would I perform this surface integral?
The discussion focuses on solving a surface integral over a spherical region defined by x^2 + y^2 + z^2 = 25, with the vector field F = r^3 r. The user initially converts Cartesian coordinates to spherical coordinates and identifies the surface area element dτ as r^2 sin(Φ) dθ dΦ. After substituting r = 5, the integral simplifies to 5^5 ∫∫ sin(Φ) dθ dΦ, leading to the realization that the limits for θ are from 0 to 2π and for φ from 0 to π. The final result for the surface integral is confirmed to be 6250π, correcting an earlier miscalculation.
Boltzman Oscillation
∫∫ Fndτ over the spherical region x^2 + y^2 + z^2 = 25
given F = r^3 r i already converted the cartesian coordinates to spherical in F
n = r[/B]
I know I can plug in F into the equation and then dot it with r to get the following:
∫∫ r^3 dτ
r should be constant at r = 5 so i can take it out of the integral and substitute
5^3∫∫dτ
now how can i solve the ∫∫dτ? I would have to convert dτ into spherical coordinates? Note: the double integral should have a circle on it but I don't know how to add one here. Any help is useful.
##d\tau## in this case is the area element for the surface of the sphere. It should be in spherical coordinates, yes. If you don't know what it is, you can calculate the volume element in spherical coordinates from the Jacobian, then make ##r## constant (thereby removing ##dr##).
Ah so dτ = r^2sinΦdθdΦ, plugging in r = 5 and then into the equation I get:
5^5∫∫sinΦdθdΦ
solving the integrals i get
5^5(θ)cos(Φ)
Close. But if those are closed integrals, ##\oint## (pretend that's a double), it isn't an indefinite integral.
Isn't it just the surface area of the sphere? Or do I misunderstand the notation?
Likes Delta2
ah so i should consider my boundaries for a sphere? Where θ is from 0 to 2pi and φ is from 0 to pi.
answer should be 6250pi
You're off by a factor of 2, but yes, the method is correct.
Got it, Thanks Dewgale.
Likes Dewgale
  • · Replies 63 ·
