How's diffraction pattern modied by phonon perturbation?
The discussion focuses on the impact of phonon perturbation on the diffraction pattern of a body-centered cubic (bcc) lattice, specifically those atomic planes parallel to the (100) orientation. It is established that phonon perturbation leads to a reduction in the amplitude of normal diffraction peaks, quantified by the Debye-Waller factor, and introduces Thermal Diffuse Scattering. These effects modify the diffraction pattern, resulting in additional peaks beyond those observed in an unperturbed lattice.
  • Understanding of phonon perturbation in solid-state physics
  • Familiarity with diffraction patterns in crystallography
  • Knowledge of the Debye-Waller factor and its implications
  • Basic principles of Thermal Diffuse Scattering
  • Research the mathematical formulation of the Debye-Waller factor
  • Explore the principles of Thermal Diffuse Scattering in detail
  • Study the effects of phonon interactions on diffraction patterns in various crystal structures
  • Investigate experimental techniques for measuring diffraction patterns in perturbed lattices
Physicists, materials scientists, and researchers studying crystallography and solid-state physics, particularly those interested in the effects of phonon perturbations on diffraction patterns.
leehoom
Hi there,
I have a problem on phonon perturbation's effect on diffraction pattern.
Assume atomic planes parallel to (100) of bcc lattice is periodically perturbed by phonon.
How will diffraction pattern be modified as a result of such perturbation? Will we see any diffraction peaks in addition to those seen for a unperturbed lattice?
Thanks!
You get a reduction in the amplitude of the normal diffraction peaks, usually described by a Debye-Waller factor, and in addition you get Thermal Diffuse Scattering.
http://en.wikipedia.org/wiki/Debye–Waller_factor
http://www.neutron.ethz.ch/education/Lectures/neutronfall/Lecture_4-2
Thank you! It's really helpful.
  • · Replies 16 ·
