Solving Erbium's Ground State w/ Hund's Rules
The discussion focuses on calculating the ground state of erbium using Hund's rules, specifically for the electron configuration [Xe]4f126s2. The user initially calculated S=1, L=5, and J=6 but was informed that the correct values are S=3, L=9, and J=12. The solution emphasizes the utility of considering holes in more than half-filled shells, which simplifies the calculation process significantly.
  • Understanding of Hund's rules in quantum mechanics
  • Familiarity with electron configurations, particularly for lanthanides
  • Knowledge of angular momentum coupling in atomic physics
  • Basic principles of quantum mechanics and Pauli's exclusion principle
  • Study the application of Hund's rules in other lanthanide elements
  • Learn about the concept of holes in electron configurations
  • Explore advanced topics in angular momentum coupling
  • Review quantum mechanics principles related to atomic structure
Students of quantum mechanics, physicists specializing in atomic structure, and educators teaching advanced chemistry concepts related to electron configurations and Hund's rules.
SteveDC
I have the solution for this problem but don't understand it.
1. Homework Statement
Use Hund's rules to calculate the ground state of erbium with electron configuration [Xe]4f126s2
Hunds Rules:
1. Maximise S (within Pauli)
2. Maximise L (within Pauli)
3. Min J (for less than half-filled orbitals) or Max J (for more than half-filled orbitals)
So I used these rules on the 12 electrons in unfilled f orbital and I arrived at S=1, L=5, and therefore J=S+L=6 but the solution which I have been given is: S=3, L=9, J=12
Can anyone confirm if the solution is correct and where I am going wrong?
Thanks
Your solution is correct.
For more than half-filled shells, it is easier to work with holes than with electrons: f12 and f2 generate the same terms. That will tell you quickly what the solution is.
Great, thanks. And cheers for the tip, the holes method is much quicker!
9K
