HVAC condensate drain line is dry?
  • Context: HVAC
  • Thread starter Thread starter arabianights
The discussion revolves around the issue of a dry HVAC condensate drain line, particularly in the context of residential heating systems. Participants explore the implications of a dry U-trap and the conditions under which water is typically present in the condensate line, considering factors such as heating methods and previous experiences with clogs.
  • One participant notes that a dry condensate line may be normal if the air conditioning is not running, as heating typically does not produce condensation.
  • Another participant emphasizes the importance of keeping the U-trap full of water to prevent cold air from being drawn into the house due to low pressure in the drain pan.
  • A different viewpoint suggests that the significance of a dry trap may depend on the drainage setup, mentioning various configurations such as draining into a floor drain or sewer system.
  • Concerns are raised about the potential for air loss if the trap is not full, particularly if the condensate line is plumbed directly into the sewer system.
Participants express differing views on the implications of a dry condensate line, with some suggesting it may be normal under certain conditions while others highlight potential issues related to air loss and drainage configurations. The discussion remains unresolved regarding the best practices for maintaining the condensate line.
Participants reference specific heating methods and drainage setups, indicating that the situation may vary significantly based on individual HVAC systems and local practices. There is an acknowledgment of previous issues with clogs and flooding, which adds context to the current concerns.
arabianights
greetings
I cleaned my residential hvac condensate drain line a couple weeks and blowed out the excess of water deposited in the U-shaped trap with compressed CO2. today when I checked the condensate line, I found the line is bone dry. temperature in my area has dropped and I usually have heat turned on when i'm home.
I'm concerned since usually the U-trap has water in it. is this normal?
Depends on several things. If you have not run the air conditioning for cooling the the evaporator will not condense water. If you are heating, you may not make any water either. What's the fuel source for heating? As far as I know only high efficiency gas furnaces with PVC pipe for exhaust make condensation.
It's all electric, no gas!
I've not run house AC since before I cleaned the condensate line, then the weather has been cold and i only use heating. My condensate drain line was clogged a year ago during summer when AC was on and caused water overflow flooding the carpeted floor adjacent to HVAC/heater units space, so now i make a habit to check and clean the condensate line regularly. if i understand correctly, running heat doesn't produce water condensation hence no water accumulated in the drain line.
I recommend keeping the trap full of water because a dry condensate pipe is a path to cold air to be sucked into the house due to the low pressure that is induced in the drain pan by the blower.
Depending on where the condensate drains, it might not matter if the trap is full. Often they drain into a floor drain. Sometimes they drain to the same place as the washing machine or a laundry sink. In this case there would likely be a condensate pump. If it drains directly into the sewer system you will definitely want water in the trap. It also depends on which side of the blower the air conditioner coil is. Sometimes they're on the suction side in which case they would draw air in from wherever they are placed. On the pressure side they will blow air out. If plumbed directly into the sewer system you'll lose a small amount of warm air into the sewer system if the trap is not full.
  • · Replies 23 ·
  • · Replies 25 ·
  • · Replies 28 ·
