Hydraulic, Fluids at Rest Problem (barrel)
The problem involves calculating the ratio of hydrostatic force on the bottom of a cylindrical barrel filled with water to the gravitational force on the water contained within the barrel. The scenario includes a tube fixed to the barrel, with specific dimensions provided for both the barrel and the tube.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of gravitational force and hydrostatic pressure, with attempts to set up equations relating pressure and area. Questions arise regarding the dependence of hydrostatic pressure on depth and area, as well as the correct approach to finding the forces involved.
Some participants have provided guidance on calculating hydrostatic pressure and emphasized the importance of depth in these calculations. There is ongoing exploration of how to correctly apply the principles of hydrostatics to find the required forces, with various interpretations being discussed.
Participants express confusion regarding the relationship between pressure, area, and force, and there is mention of needing to account for atmospheric pressure in the calculations. The problem's setup and the specific dimensions of the barrel and tube are central to the discussion.
azrida
In the figure below, an open tube of length L = 1.8 m and cross-sectional area A = 4.6 cm2 is fixed to the top of a cylindrical barrel of diameter D = 1.2 m and height H = 1.8 m. The barrel and tube are filled with water (to the top of the tube). Calculate the ratio of the hydrostatic force on the bottom of the barrel to the gravitational force on the water contained in the barrel.
P=phg
F=mg=pvg
F=pa
F1/A1 = F2/A2
Okay, this problem has been giving me a major headache.
I tried to solve this by finding the gravitational force in barrel, which I assumed as:
mg = pvg = (1000kg/m^3)(0.6m^2*pi*1.8m)(9.8m/s^2) = 19940.256 N
Then I "attempted" to set up an equation to find the hydrostatic force on the bottom of the barrel, where I got stuck:
F1/A1=F2/A2
-> Atmospheric pressure/area of the tube = Hydraulic pressure/are of the bottom of the barrel
I already know that the answer is 2, but I need to learn HOW and WHY it is so.
HELP, PLEASE! :-( !
pics at http://www.webassign.net/hrw/hrw7_14-31.gif
F1/A1=F2/A2
First find the water pressure at the bottom of the barrel. What does hydrostatic pressure depend on? At what depth below the water surface is the bottom of the barrel?
Would the water pressure at the bottom of the barrel be:
pressure of the tube on the top + pressure of the water in thebarrel
-> pgAh + pgAh -> (1000kg/m^3)(9.8m/s^2)(0.00046m^2)(1.8m) + (1000kg/m^3)(9.8m/s^2)(0.6m^2)(pi)(1.8m)
-> 20021.4 ?
Does hydrostatic pressure depend on the area where pressure is applied onto??
The bottom of the barrel is 1.8m away from the top of the barrel (not including the tube)
Can someone please explain the whole process step by step?
I really feel like I'm getting lost here :-(
-> 20021.4 ?
-> 20021.4 ?
No. The area doesn't matter for caculating pressure.
No. (You'll need the area when you find the force, but not the pressure.)
What matters is how far below the water surface the bottom is. There's water in the tube!
Doc Al said:
No. The area doesn't matter for caculating pressure. No. (You'll need the area when you find the force, but not the pressure.)What matters is how far below the water surface the bottom is. There's water in the tube!
So... the water pressure at the bottom of the barrel is:
P = phg = (1000kg/m^3)(3.6m)(9.8m/s^2) = 35280(Pa??)
and since F = p*a,
(35280)(area of the bottom of the barrel) = force
(35280)(0.6^2)(pi) = 39880.512 Nand the grativational force on the water contained in the barrel is:
mg = pvg = 19940.256 N
so, the ratio of the hydrostatic force on the bottom : gravitational force = 39880.512/19940.256 = 2 !
Wow! Thank you so much :-)!
Good. But don't forget to add in atmospheric pressure.
and since F = p*a,
(35280)(area of the tube?) = force?
Since you want the force on the bottom of the barrel, use the area of the bottom of the barrel (not the tube).
am I following you correctly?
Yes.
Yes.
Thank you so much!
I think now I know the concept behind this probelm :-)
  • · Replies 21 ·
