Hydro Power is Actually Solar Power
The discussion centers around the relationship between hydroelectric power and solar energy, exploring the idea that hydro power is fundamentally a form of solar power due to the processes involved in water elevation and energy generation. Participants also touch on related energy sources such as tidal and geothermal energy, examining their connections to solar and nuclear energy.
  • Historical
  • Some participants propose that hydroelectric power is ultimately derived from solar energy, as water is elevated through solar heating before being used to generate power.
  • Others argue that this perspective could apply to various forms of energy generation, including wind and tidal power.
  • Several participants assert that all forms of power can be categorized as either nuclear or solar, leading to a debate about the implications of this classification.
  • There is a discussion about the role of gravitational collapse in the sun's nuclear fusion process, with differing views on its significance as a source of energy.
  • Some participants challenge the assertion that geothermal energy is not based on solar energy, suggesting it is instead related to nuclear decay processes in the Earth's mantle.
  • A historical reference is made to the debate between Lord Kelvin and Charles Darwin regarding the age of the Earth and the source of solar energy, highlighting the evolution of scientific understanding over time.
Participants express multiple competing views regarding the classification of energy sources and the relationships between solar, nuclear, and gravitational influences. The discussion remains unresolved with no clear consensus on the definitions or implications presented.
Participants acknowledge the complexity of energy sources and their interdependencies, with some discussions highlighting unresolved assumptions about the origins and classifications of energy types.
Frank Peters
Hydroelectric power, effected usually by damming a river, is ordinary considered an example of energy produced by gravitational potential.
However, from an ultimate perspective, hydro power is actually an example of solar power.
Water must drop to a lower gravitational potential to extract energy, and this drop occurs as a river flows downward. But to keep the dam working indefinitely water must also continuously be elevated, or raised, in potential. This elevation of water occurs via solar heating. The sun vaporizes
water and this water vapor will later condense as rain or snow at higher elevations. Without this continual elevation of large amounts of water to a higher gravitational potential hydroelectric power would not be possible.
This issue may not seem greatly significant but it's always a good idea to try to understand things from different perspectives.
By that definition, all power is either nuclear or solar.
But we really are not worried about the origins, only the immediate form of energy generation
aka hydro generation
your idea could be used to describe many forms of energy generation ….
wind turbines and tidal to name a couple more.
see if you can come up with any othersDave
Which means it's all nuclear, since that's what powers the sun.
What about tidal power?
I mentioned that along with wind ... caused by the sun in one form or another
(well some moon as well for the tides)
checkmate 😉
Is that correct?
The nuclear fusion within the sun is caused by gravitational collapse. So it seems that, ultimately, it is gravity that powers everything.
No it isn't.
Geothermal energy is also not based on Solar. Tidal power is based on the potential energy of Earth Moon ecosystem.
But ultimately by gravity.
russ_watters said:
No it isn't.
It kind of is. Gravitational collapse is the reason the core reached the heat and pressure required for fusion ignition, and is continuing to increase the pressure and temperature in the core (increasing the output of the sun) as the core density increases due to the accumulation of helium. It's not the direct source of the energy coming out of the sun, but it is indirectly responsible.
It can be said to provide activation energy, but that's like saying the blasting cap is the energy source instead of the dynamite. It might be interesting to try and figure out what fraction of the energy that is though...
About one part in a million, from memory. A serious early argument against Darwin was that the Sun was assumed to be radiating its gravitational potential energy and therefore couldn't be much over 10,000 years old. Compare its expected ten billion year lifetime when you factor in fusion.
I may be off by an order of magnitude
Another nuclear source, right? Isn't the geothermal heat provided by decay of radionuclides in the mantle?
That's what I thought.
That was one of the big arguments between Lord William Thompson Kelvin and Charles Darwin.
According to Kelvin the source of Solar energy was due to Gravitational contraction. Because of that he kept the age of Sun and Earth to be around 20-100 Million Years. Where as on the first version of "On the origin of species", Darwin said that evolution took more than 300 Million years. Kelvin vehemently opposed it because the Sun was only 20 Million years old. Anyway for the 2nd edition of the book, Darwin avoided the problem by not giving any real number of years. :)
  • · Replies 25 ·
12K
  • · Replies 21 ·
