Mathmos6
- 76
Hi all - I've done all but the last part of this problem, for which I have the solution, but I was hoping someone could explain why the solution is what it is :)
q:The Hamiltonian of a quantum system suddenly changes by a finite amount. Show that the wavefunction must change continuously if the time-dependent Schrödinger equation is to be valid throughout the change.
Show that the ground-state wavefunction for a hydrogenic atom (a bound state of one electron and a nucleus of charge Ze, with Z a positive integer) takes the form
\psi_{0}(r) = \frac{1}{\sqrt{\pi a^3}}exp(\frac{-r}{a})
and determine the dependence of the constant a on Z. Such a hydrogenic atom is in its ground state. The nucleus emits an electron, suddenly changing to one with charge (Z + 1)e. Compute the probability that if the energy is now measured, the atom will still be found in its ground state.
Now it's just the red bit I'm stuck on - I've done the rest, but to save rewriting the formula every time you use it, you can just call it \psi_{0}(r,a) if it's easier.
I have from the previous parts a=\frac{4 \pi \epsilon_{0} h^2}{z e^2 m}, where h is actually the 'h-bar' version of Planck's constant, but I'm not sure how to LaTeX that!
Now in the solution I have, the probability given is
\frac{1}{\sqrt{\pi a^3}}}\frac{1}{\sqrt{\pi \tilde{a}^3}}}\int_0^{\infty} exp(-\frac{r}{a})exp(-\frac{r}{\tilde{a}})r^2\, dr \,sin(\theta)\,d\theta\,d\phi
(possibly with some mod bars somewhere), the calculation of which is fairly simple - where '\tilde{a}' is \frac{a z}{z+1}, i.e. the new value of 'a' you'd have if z was z+1 - which makes the integral
\int_0^{\infty} \psi_{0}(r,a)\psi_{0}(r,\tilde{a})r^2\, dr \,sin(\theta)\,d\theta\,d\phi I believe.
Why is it this to begin with? It doesn't seem to be the standard 'probability is mod wavefunction squared' because there's one a and one \tilde{a} - can anyone explain?
One other thing, I'm not good with bra-ket notation(Dirac notation) so unless absolutely necessary words/other notation would be much more appreciated!
Thanks very much all :)
