Hydrostatic Problem: Three tube Manometer
The discussion centers on the behavior of water in a three-column manometer connected to a reservoir. When the valve at the end of the horizontal tube is opened, the water level in the column closest to the valve (Column 3) experiences a greater change in height compared to the column nearest the reservoir (Column 1). This phenomenon is attributed to the pressure gradient created between the reservoir and the valve, which drives the flow of water through the manometer. The pressure difference is crucial in understanding the flow dynamics in this setup.
  • Understanding of hydrostatic pressure principles
  • Familiarity with manometer design and function
  • Knowledge of fluid dynamics and pressure gradients
  • Basic concepts of atmospheric pressure effects on fluid columns
  • Study the principles of hydrostatic pressure in fluid mechanics
  • Explore the design and applications of different types of manometers
  • Learn about pressure gradient calculations in fluid systems
  • Investigate the effects of atmospheric pressure on fluid behavior in open systems
Students and professionals in physics, engineering, and fluid mechanics who are looking to deepen their understanding of manometer behavior and fluid dynamics in pressure-driven systems.
Mokha75
Hi guys, new to the forum here.
I have of a conceptual question that I can't wrap my head around.
Here's the situation: there's a reservoir filled with water attached to a "three-column manometer" with each column open to the atmosphere. The horizontal tube that connects all three of the columns at the bottom, has a valve at the end. The valve is in the closed position and then opened to let the water run through.
What I would like to know is when we do this, for a given time period, why do see the water in the column closest to the valve (column 3 below) have a greater change in height as compared to the column closest to the reservoir (column 1)?
Hope I'm making sense
here's my lame attempt at drawing the apparatus:
(__Reservoir__)-------I--------------I-------------I--valve
Column 1 Column 2 Column 3
Well, the flow of matter from one side to another will occur due to a pressure difference between the reservoir and valve. The water in the horizontal tube experiences a pressure gradient from the reservoir to the valve, and that is what causes the flow in that direction.
At the same time, this pressure gradient can be observed by placing several vertical columns along the horizontal tube.
Thanks!
  • · Replies 26 ·
  • · Replies 23 ·
