Can cosh(x)cosh(y) be rewritten in terms of k=Cosech(x)*Cosech(y)?
The discussion explores whether the expression Cosh(x) * Cosh(y) can be exclusively expressed in terms of k = Cosech(x) * Cosech(y). Despite attempts to manipulate hyperbolic identities, participants find that expressing Cosh(x) * Cosh(y) solely in terms of k leads to inconsistencies. Specifically, different values of sinh(a) and sinh(b) yielding the same k produce varying results for Cosh(x) * Cosh(y). This indicates that a single function f(k) cannot represent Cosh(x) * Cosh(y) uniquely for all cases. Ultimately, the conclusion is that it is not possible to rewrite Cosh(x) * Cosh(y) exclusively in terms of k.
emanuele.levi
Given the quantity
Cosh(x)*Cosh(y)
where x and y are two indipendent real variables is it possible to write it only in function of
It could seem a quite easy problem but I spent a few days between the proprieties of hyperbolic functions and I really didn't find a way to solve it.
Mathematics news on Phys.org
Hint:
Use the identity (cosh(t))^2-(sinh(t))^2=1 to solve for cosh(t).
Then use the fact that csch(t) = 1/sinh(t) so sinh(t) = 1/csch(t).
thank you for the hint Russell,
but that's not a solution to my problem, as I want to write the quantity
Cosh(x)*Cosh(y)
ONLY in function of k. If I did like you suggested me, I find terms like
Sinh(x)+Sinh(y)
and I can't find a way to write them in function of k.
It is not possible.
Assume you have some function f(k) that represents cosh(x)cosh(y) in terms of k.
When k = 1/2, then what would f(k) be?
Let sinh(a)=.5, sinh(b)=4. Then k = 1/(.5*4) = 1/2
Then cosh(a)*cosh(b)=sqr( 1+1/4)*sqr( 1+16)=sqr(85/4)=f(1/2)
However look at:
let sinh(c)=1, sinh(d)=2. Then k = 1/(1*2) = 1/2
But cosh(a)*cosh(b)=sqr( 1+1)*sqr( 1+4)=sqr(10)=f(1/2)
So, f(1/2) would not have a single output value, it is not a function.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 0 ·
