I have an error in integrating to calculate the age of the Universe
The discussion revolves around the integration process to calculate the age of the Universe using cosmological parameters. Participants explore the mathematical formulation, numerical calculations, and formatting issues related to LaTeX for presenting equations.
  • Meta-discussion
  • One participant presents a detailed integration approach to calculate the age of the Universe, using specific values for cosmological parameters.
  • Another participant critiques the precision of the numerical values used, suggesting they contain excessive digits.
  • Several participants discuss the importance of using LaTeX for clarity in mathematical expressions, with one expressing difficulty in formatting equations correctly.
  • A participant suggests an alternative integral formulation that may yield a more accurate result for the age of the Universe.
  • There are mentions of external resources for learning LaTeX, with some participants sharing links and advice on how to use it effectively.
  • One participant expresses confusion regarding the advice given about rounding numbers and the significance of precision in the context of cosmological calculations.
  • Another participant notes that the derivation of certain cosmological integrals may not have an analytic solution when neglecting specific parameters.
Participants express differing views on the appropriate level of precision in numerical calculations and the clarity of mathematical presentation. There is no consensus on the best approach to the integration or the formatting of equations, indicating ongoing debate and exploration of ideas.
Some participants highlight the limitations of their current understanding of LaTeX and the challenges faced in presenting complex mathematical expressions. Additionally, there are unresolved questions regarding the accuracy of the integration results and the implications of different cosmological models.
This discussion may be useful for individuals interested in cosmology, mathematical modeling, and those seeking to improve their skills in LaTeX for presenting scientific equations.
Buzz Bloom
TL;DR
I am seeking help in finding my error. I am integrating the Friedmann equation (with just H_0, Ω_m, and Ω_Λ) expecting a result of about 13.8 x 10^9 years. My result and how I calculated it is in the main body of this post.
NOTE: I am attempting to convey the equations in this post into LaTerX format in Post #19.
My result is way off. It is about 7.44 x 10^9 years. The values I use are:
1/H_0 = 14.4 X 10^9 years,​
M = Ω_m = 0.3103, and​
L = Ω_Λ = 1 - Ω_m = 0.6897.​
The equation I start with is the following.
dt = (1/H_0) (1/(M/a^3 + L)^(1/2)) (da/a)
I make the following substitutions.
x = a^3 and a = x^(1/3),​
da = (1/3) dx / x^(2/3)​
Q = (1/2) M/L and M/L = 2Q​
This leads to the following equation.
dt = (1/3) (1/H_0) (1/L^1/2)) dx / (x^2 + 2Q x)^(1/2)
Integrating produces
t = (1/3) (1/H_0) (1/L^(1/2) [log ( x+Q + (x^2 + 2Qx)^(1/2) )].​
Note: I did differentiate the above integration result to confirm it leads to the previous differential equation.
Calculating the value of t uses the integration limits between x=a=0 and x=a=1. The result is the following.
t = (1/3) (1/H_0) (1/L^(1/2) log (W(1) / W(0)), where​
W(1) = 1+Q + (1+2Q)^(1/2), and​
W(0) = (Q+2Q)(1/2).​
Now comes the numerical calculations.
(1/3) (1/L^(1/2) (1/H_0) = (1/3) (1/0.6897)^1/2 14.4 x 10^9 years​
~= 5,780,000,000 years.​
W(1) ~= ~2.43​
W(0) ~= 0.896​
W(1)/W(0) = ~2.71​
log(W(1)/W(0)) =~1.00​
t = (1/3) (1/L^(1/2) (1/H_0) log (W(1) / W(0))​
~=5,780,000,000 years X ~1.00 ~=5,770,000,000 years​
Space news on Phys.org
Buzz Bloom said:
0.997656155687048
Of for goodness sake. You can start by making it easier on people who might want to help you by proper rounding. Make it easy for them, not hard.
Hi @Vanadium 50:
I would much appreciate your specific suggestion about "rounding". I do not have any instinct about how much is enough.
Regards,
Buzz
Hi @PeterDonis:
It has been a very long time (years) since I last used LaTeX. My memory about it has vanished. Would you please tell me how I can find the instructions about how to use LaTeX?
Regards,
Buzz
You should know that those numbers have way too many digits of precision. If you don't, you need to take a step back and brush up on basic mathematics before tackling cosmology. Whether the correct number of digits is three or four or something else is less relevant that 156752675.6786876877686876876167861876 is clearly not right.
Peter is also right - a second reason that your post is unreadable is you didn't bother to make it clear by using LaTexX.
If you make it hard on the people who you want to help you, you will get less help.
Age of the universe? Order of magnitude, second digit is excessive/hubris.
Hi @Vanadium:
I will take your advice and use 3 digits.
Regards,
Buzz
Hi @Bystander:
Your comment "Order of magnitude, second digit is excessive/hubris," does not communicate to me at all. I just do not get what you are trying to tell me.
Regards,
Buzz
There's a "LaTeX Guide" link at the bottom left of the edit window when you're making a post.
Bystander said:
Age of the universe
Is 13,700,000,001 years old. I know that because last year I read it was 13.7 billion years old.
  • Love
  • Haha
Hi @PeterDonis:
I am editing Post #1 to try to convert equations to LaTeX, but I am so far not able to succeed on my first equation. Can you help me?
Regards,
Buzz
You know better than that! Write a new messgae - don't change messages that have already received replies.
It looks like you already got a harder equation right. You just need to be patient.
Also, @Vanadium 50 is right that you should not be editing the OP. Instead add new posts with equations in LaTeX as you do them.
That looks more complicated than necessary. Pulling the ##a## in the denominator (from ##a H_0##) inside the square root in your integrand gives for the integral (we can also pull ##H_0## out in front of the integral since it's a constant):
t =\frac{1}{H_0} \int_0^1 \frac{da}{\sqrt{\frac{M}{a} + L a^2}}
Evaluating this integral should give you a much closer answer.
Hi @PeterDonis:
I very much appreciate your comments and your advice. I will start a new post with a gradual intent to attempt to use LaTeX to complete the sequence that explains the integration.. When I edited Post 1, I alternated editing and then posting so I could see if the LaTeX I used for an equation was OK. I ran into a problem in that when I posted the edit, it did not show the LaTeX form. I have decided that in order to see the result in Latex form, I will need to log out of the Physics Forums and then re-enter.
Regards,
Buzz
THIS POST IS NOW COMPLETED.
Note that I have finally corrected my errors and have calculated an expected result.
$$dt = \frac {da} {H_0 a \sqrt {M/a3+L}} = \frac {{\sqrt {a}} da} {H_0 \sqrt {M+L a^3}}$$
##{x = a^3,}## ##{a = x^{1/3}},## ##{da = dx / 3x^{2/3}},## ##and## ##{M/L = 2Q}.##
$$dt = \frac {dx} {3H_0 \sqrt L \sqrt{x^2 + 2Qx} }$$
$$t = { \frac {1} {3H_0 \sqrt L}} {\ln ( {x+Q + \sqrt {x^2 + 2Qx} } ) }$$
NOTE: Post #28 shows the differentiation of the above resulting in the dt equation above.
Evaluating the numerical integration range is for x=a=0 to x=a=1.
$$t = {\frac {1} {3H_0 \sqrt L}} {\ln ( {\frac {1+Q + \sqrt {1 + 2Q} } {Q} ) }}$$
##{1/H_0} =14.4 giga-years,##
##M = {Ω_m} = 0.3103 ##,
##L = {Ω_Λ} = {1 - Ω_m} = 0.6897, ##
## \sqrt {L} = 0.8305,## and
##Q = {M/2L} = 0.2250.##
##{\frac {1+Q + \sqrt {1 + 2Q} } {Q} } = \frac {{1.2250} + \sqrt {1.45}} {0.2250}## = 10.80
##{\ln ( { \frac {1+Q + \sqrt {1 + 2Q} } {Q} } )} = {2.38} ##
##t = {\frac {2.38} {3 H_0 0.8305}} = {\frac {2.38} {2.4915}} ({1/H_0}) = 0.9552 ({1/H_0})##
##t = {13.76}## giga-years
No, just refresh the page with the little spinny arrow thingy:
PF uses an optimization called "lazy loading" for LaTeX (I think), which means that the LaTeX is not rendered until you refresh your browser at least once.
(It's a feature, not a bug...) :wink:
Hi @pbuk:
I am very familiar with the reference you posted. My first LaTeX equation in Post #19 is based on the equations in your reference, except I omit ##Ω_r## and ##Ω_k##.
Regards,
Buzz
In that case you will have seen the derivations for approximations to ## a(t) ## neglecting all but one of ## \Omega_M, \Omega_R \text{ and } \Omega_\Lambda ## (as well as ## \Omega_k ##). There is no derivation neglecting only ## \Omega_M ## (as well as ## \Omega_k ##) because there is no analytic form for this integral.
The case that @Buzz Bloom considers here, ##\Omega_R = 0## and ##\Omega_M + \Omega_\Lambda = 1##, does have invertible closed form analytic solutions, i.e., there are closed form expressions for both ##a\left(t\right)## and ##t\left(a\right)## in this case.
$$t = { \frac {1} {3H_0 \sqrt L}} {\ln ( {x+Q + \sqrt {x + 2Q} } ) }$$
I have not checked anything else, but differentiating
$$t = \frac {1} {3H_0 \sqrt L} \ln \left( x+Q + \sqrt {x + 2Q} \right)$$
does not seem to give
$$dt = \frac {dx} {3H_0 \sqrt L \sqrt{x^2 + 2Qx} }.$$
According to Dwight's book, formulae 380.001, the result of the integration is:
##t=\displaystyle\frac{1}{3H_0\sqrt{L}}\ln[2(x+Q+\sqrt{2Qx+x^2})]##
Hi @George Jones:
Thank you for responding to my problem. I should have made clear that I have not completed the presentation I am working on in Post #19.. The equation with ##t = ## has errors due to my lack of experience using LaTeX I have not fixed yet. The equation should be
Regards,
Buzz
When I differentiate the
equation, I get
$$ dt =({ \frac {1} {3H_0 \sqrt L}}) ({\frac {1} {x+Q + \sqrt {x^2 + 2Qx} }}) ({1 + {\frac {2x+2Q} {2{\sqrt {x^2 + 2Qx}}}}})$$
This simplifies to
$$ dt =({\frac {1} {3H_0 \sqrt L}}) ({\frac {1} {x+Q + \sqrt {x^2 + 2Qx}}})
({\frac {x+Q + \sqrt {x^2 + 2Qx}} { \sqrt {x^2 + 2Qx}} } )$$
and
$$ dt =({\frac {1} {3H_0 \sqrt L}}) ( {\frac {1} { \sqrt {x^2 + 2Qx}} } )$$
The above is the integrand I originally integrated.
##t=\displaystyle\frac{1}{3H_0\sqrt{L}}\ln\frac{1+Q+\sqrt{1+2Q}}{Q}##
##L=0.6897## ##\sqrt{L}=0.8305##
##t=13.75## Gyr
Hi @mbond:
Thank you for your post. I would much appreciate it you would post the reference of the integral with the x variable which leads to your "t = ..." equation. The equation I reached is
$$t = { \frac {1} {3H_0 \sqrt L}} {\ln ( {x+Q + \sqrt {x^2 + 2Qx} } ) }$$.
If this is wrong, can you tell me where my error is?
Keep in mind that the numerical integration is from x=0 to x=1.
Regards,
Buzz
  • · Replies 21 ·
  • · Replies 20 ·
