Ideal Gas law and a hot air balloon problem
The discussion focuses on calculating the average temperature of the air inside a hot air balloon using the Ideal Gas Law and buoyancy principles. The total mass of the unfilled balloon and payload is 500 kg, and the radius of the balloon is 15 m. Key equations include the Ideal Gas Law (PV=nRT) and the buoyant force equation derived from Archimedes's principle. Participants emphasize the need to relate the buoyant force to the gas law to find the mass of the air inside the balloon, which is crucial for determining the temperature.
  • Understanding of the Ideal Gas Law (PV=nRT)
  • Knowledge of buoyancy and Archimedes's principle
  • Familiarity with density calculations (density = m/V)
  • Basic grasp of thermodynamics and gas properties
  • Explore the application of Archimedes's principle in fluid mechanics
  • Study the derivation and application of the Ideal Gas Law
  • Investigate the relationship between pressure, volume, and temperature in gases
  • Learn how to calculate buoyant forces in different fluid scenarios
Physics students, engineers, and anyone interested in thermodynamics and fluid mechanics, particularly those working with hot air balloons or similar applications.
wilsbran
My physics problem is as following,
Estimate the average temperature of the air inside a hot air balloon. Assume that the total mass of the unfilled balloon and payload is 500kg. what is the mass of the air inside the balloon?
we are told to use a radius of 15m
Equations needed
density = m/V
ideal gas law PV=nRT
Pressure = Force over area.
This is what i Have so far:
Fnet = Fbuoyant - Fgravity
because the balloon is assumed to be in equilibrium Fnet = zero
0= density*V*g -(mass of air+mass of payload)*g
Its here that i start to get confused. I think that the density is the density of the air alone because it is the buoyant force of the heated air pushing up on the balloon so to speak.
I know that there is a relation to the gas law and from that the temperature of the balloon can be calculated...but i am stuck at this:
P= density*R*T
any suggestions/help?
You can easily find an expression Fbuoyant using Archimedes's principle. What is Fgravity? It's the weight of the unfilled balloon plus the weight of the hot air in it. If you are going to use the ideal gas law (which you should) you need to consider the pressure of the hot gas.
i have used the expression for the buoyant force
density*V*g = (mass of air+mass of payload)*g -------> eqn (1)
where density*V*g is the the buoyant force
i am having trouble relating it to the gas law. I know that
density = m/V
so PV=nRT can be seen as
P = density*R*T / Molar Mass
but from the force equation (eqn (1) above) i have I'm not sure how to proceed as i do not know the mass of the air.
The mass of the air is mair=Nm, where N = number of molecules and m = mass of one molecule. Use the ideal gas law in the form pV = NkT to replace N in the mass expressions for the gas inside and outside the balloon.
